Cruise Control
Results 1 to 8 of 8
Cadillac SRX Second Generation Forum (2010-2016) Discussion, Cruise Control in Cadillac SRX / XT5 Forums; Yesterday after a stop at a rest stop on the NJ Turnpike, I couldn't set the cruise control on my ...
    cannon1017 is offline Cadillac Owners Member
    Automobile(s): 2012 Cadillac SRX 2012 CTS
    Mar 2009
    Wilmington, DE
    33
    Cruise Control
    Yesterday after a stop at a rest stop on the NJ Turnpike, I couldn't set the cruise control on my 2012 SRX. Tried the button located to the left of the set/resume button and got nothing. No icon on the dashboard, nada. Never had a problem with it before. Anyone else having this issue?
    TheCaptain's Avatar
    Aug 2009
    Moosomin Saskatchewan
    30
    3,075
    Re: Cruise Control
    There was one other person on here that had that problem, but then we figured out they had actually turned cruise off.
    If I remember my buttons right, it sounds like you are trying to turn the main cruise button on and it isn't working. Once you have a few minutes at home, open the battery cover and pull off the negative terminal for 30 seconds. It should reset the whole system. Let us know if it doesn't work beyond this little 'reset'.
    njacobsen is offline Cadillac Owners Fanatic
    Automobile(s): 2017 XT5, Platinum, Dark Granite Metallic, 20" Ultra-Bright
    Dec 2012
    WI
    486
    Re: Cruise Control
    If you had no icon on the dash, you have likely turned the cruise off. Press the button to the right of the set/resume and the icon should come back on. That button toggles the cruise off/on. When on, the icon on the dash will be white. When cruise is engaged, the icon will be geen. When off, the icon will be gone.
    Mar 2009
    Wilmington, DE
    33
    Re: Cruise Control
    njacobson, I tried that and still no icon. I am going to try TheCaptain's fix tomorrow.
    Mar 2009
    Wilmington, DE
    33
    Re: Cruise Control
    Captain, I mentioned your fix suggestion to my son and he recommended just unplugging the ECU fuse so that I wouldn't lose my presets and other electronic info. He did that and it worked. Cruise control is working again.
    TheCaptain's Avatar
    Aug 2009
    30
    3,075
    Re: Cruise Control
    Different path, same result. Good to know it worked!
    marabe is offline Cadillac Owners Member
    Automobile(s): SRX
    Nov 2015
    1
    Re: Cruise Control
    Same year, same car, mine stopped working yesterday
    2012 SRX, cruise stopped working yesterday
    bdaved is offline Cadillac Owners Member
    Automobile(s): 2010 Cadillac SRX Premium 2.8L T
    Aug 2006
    Fruit Heights, UT
    14
    Re: Cruise Control
    Quote Originally Posted by cannon1017 View Post
    Can you tell me which fuse this is? Nothing lists a ECU fuse. Thanks for the help.
  11. Remove Advertisements
