What kind of gas in 2013 SRX??
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Like Tree12Likes
Cadillac SRX Second Generation Forum (2010-2016) Discussion, What kind of gas in 2013 SRX?? in Cadillac SRX / XT5 Forums; I was wondering if anyone can give me advice on what type of gas to use in my 2013 Performance ...
    Whistlingdixiee is offline Cadillac Owners Member
    Automobile(s): 2013 SRX Performance, Glacier Blue
    Jan 2013
    15
    Performance SRX. I think I read that regular unleaded gasoline is recommended, but should
    you use premium if you can? Or would that be a waste? TIA
    st4422's Avatar
    st4422 is offline Cadillac Owners Fanatic
    Automobile(s): 2013 SRX Premium Black Ice, 2009 CTS DI Thunder Gray
    Jun 2007
    New Mexico
    337
    Re: What kind of gas in 2013 SRX??
    The engine in your 2013 SRX is tuned to run on regular unleaded. There is no benefit to using higher octane fuel. This has been widely discussed elsewhere on these forums. Save the money and spend it on some nice accessories.
    adamjeeps is online now Cadillac Owners Connoisseur
    Automobile(s): 2012 SRX Performance FWD
    Oct 2007
    1,510
    I would add to use a top tier gasoline from this list:
    www.toptiergas.com/retailers.html
    If you can find it in ethanol-free and the price is not too high, even better.
    carbeck is offline Cadillac Owners Fanatic
    Automobile(s): 2014 SRX AWD Premium, previously 2011 AWD Luxury
    Jan 2012
    135
    Quote Originally Posted by adamjeeps View Post
    Waste of time. 2012 and newer SRXs can take up to E85. Avoiding ethanol won't help a thing.
    Find a top tier retailer and use 87, or 89 if the price is equal or less.
    Oct 2007
    1,510
    Quote Originally Posted by carbeck View Post
    We will have to agree to disagree on the ethanol. It is a fact the more ethanol content gasoline will result in poorer gas mileage. And I don't know where you would find 89 octane cheaper than 87.
    Jan 2012
    135
    Where I live, the only top tier provider has 87 and 89 for the same price. Both have 10% ethanol. Non-top tier stations have 89 with ethanol and 87 without it. The 89 is cheaper.
    Cross the state line, and the same top tier provider charges more for the 89, and non-top tier stations have ethanol 89 and non-ethanol 87 for the same price. Apparently we get a discount on this side for having ethanol in the fuel.
    Oct 2007
    1,510
    In Virginia, and nearby West Virginia, we have 87, 89, and 93. Nearly all are 10% ethanol. The 89 is about 10-15 cents more and the 93 is about 40 cents higher than 87. You can find 87 and 93 ethanol free scattered about. It usually runs 10-20 cents higher than the 10%.
    Huey Driver is offline Cadillac Owners Fanatic
    Automobile(s): 2014 ELR
    Sep 2011
    Fairfax, VA
    54
    311
    Top Tier is required to have between 8% & 10% ethanol, if I read the specs right.
    I make no judgement about the value of the Top Tier program. I suppose it could be argued the same as dino vs syn oil or even 3k oil changes vs OLMS. However, I tend to stick with name brand gasoline, and find that Top Tier is available and competitively priced. All things being equal, and the recommendation in the users manual to use it, I figure I at least have a little of an upper hand with the service dept if I ever have any fuel issues if I can confidently say its all I've ever used.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,710
    Good morning Whistlingdixiee,
    It is recommended to use regular unleaded gasoline with a posted octane rating of 87 or higher in the 2013 SRX. Per the manual, E85 (85% ethanol) and other fuels containing more than 15% ethanol must be used only in flex fuel vehicles.
    I hope this is helpful for you!
    Sarah (Assisting Katie), Cadillac Customer Service
    a1994114a is offline Cadillac Owners Member
    Automobile(s): SRX
    Jul 2016
    Fuel
    Use of the recommended fuel is an
    important part of the proper
    maintenance of this vehicle. When
    driving in the U.S. and Canada, to
    help keep the engine clean and
    maintain optimum vehicle
    performance, we recommend using
    TOP TIER Detergent Gasolines.
    See www.toptiergas.com for a list of
    Use regular unleaded gasoline
    meeting ASTM specification D4814
    higher. Do not use gasoline with an
    octane rating below 87, as it may
    cause engine damage and will lower
    fuel economy.
    Use of Seasonal Fuels
    Use summer and winter fuels in the
    appropriate season. The fuels
    industry automatically modifies the
    fuel for the appropriate season.
    If fuel is left in the vehicle tank for
    long periods of time, driving or
    starting could be affected. Drive the
    vehicle until the fuel is at one-half
    tank or less, then refuel with the
    current seasonal fuel.
    Prohibited Fuels
    Gasolines containing oxygenates
    such as ethers and ethanol, as well
    as reformulated gasolines, are
    available in some cities. If these
    gasolines comply with the
    previously described specification,
    then they are acceptable to use.
    However, E85 (85% ethanol) and
    FlexFuel vehicles.
    {Caution
    Do not use fuel containing
    methanol. It can corrode metal
    parts in the fuel system and also
    damage plastic and rubber parts.
    That damage would not be
    covered under the vehicle
    warranty.
    Some gasolines, mainly high octane
    racing gasolines, can contain an
    octane-enhancing additive called
    methylcyclopentadienyl manganese
    tricarbonyl (MMT). Do not use
    gasolines and/or fuel additives with
    MMT as they can reduce spark plug
    life and affect emission control
    system performance. The
    malfunction indicator lamp may turn
    on. If this occurs, see your dealer
    for service.
    My ignorance. I completely didn't understand what number of fuel should be used by reading the 2013 SRX Manual.
    MI-SRX's Avatar
    MI-SRX is offline Cadillac Owners Enthusiast
    Automobile(s): '14 SRX4 Perf., Crystal Red Shale/Brownstone, DAP, spare
    Nov 2013
    SE MI
    675
    ...2012 and newer SRXs can take up to E85.....
    Not true. It may be only '12 and '13 model years. I know my '14 specifically says not to use E85 - don't know about '15 and '16.
    jbeez is offline Cadillac Owners Member
    Automobile(s): 2013 SRX Luxury AWD
    Apr 2016
    3
    I have a 2013 SRX and I've been noticing a ping or knock under load, going up hills or when I first hit the gas pedal. It's got about 20,000 miles on it. I'm using 87 octane gasoline, and it happens but less when using 89 octane, and I don't hear it with 93. The owners manual says if it does that with 87 in to service the engine. I went to the dealer for an oil change and had them check this out they just told me I should be using 93 and suggested a $100 fuel system cleaning service. When I contact cad service on twitter they just refer me to a dealer.... wtf?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,821
    Dealership upselling. What does your owner's manual say about fueling????
    The 87 is perfectly fine for quiet daily driving. If you have a lead foot, tow trailers or do mountain driving I would routinely run 91/93.
    A slight rattle at acceleration or throttle application at speed may well be due to a dirty EGR (Exhaust Gas Recirculation) valve pintle or passages. Use a Top Tier gasoline (Google it) and try a 20 oz. bottle of Chevron TECHRON at your next fill-up.
    When was the last time you took the car to the boondocks, with a tank of 91/93, and engaged in an hour of "spirited acceleration and deceleration"?
  16. #14
    Apr 2016
    3
    It primarily my wife's vehicle. She drives it mostly to and from work with eco mode on. That said we used it for a 12hr road trip to Maine in June and I drove part of the trip, I had a few spirited sessions on some open expanses of road. It's also when I first noticed the pinging.
    Well aware of what stations sell top tier gasoline. We purchased this certified preowned a few months ago this year, and have no idea what kind of gas the previous owner used in it. I'll be running a bottle of BG44k through it when it gets here. For now I have 93 octane in it(from Exxon).
  17. #15
    KRDCAD's Avatar
    KRDCAD is online now Cadillac Owners Enthusiast
    Automobile(s): 2015 SRX LUX 2014 CTS LUX Phantom Grey (previously 2008 STS)
    Jun 2016
    Tidewater Virginia
    74
    561
    Quote Originally Posted by jbeez View Post
    Good stuff. I expect regular Tecron use will also help. You should not have to use any higher octane than 87
  18. Remove Advertisements
