2013 SRX After Market Antena
Results 1 to 7 of 7
Cadillac SRX Second Generation Forum (2010-2016) Discussion, 2013 SRX After Market Antena in Cadillac SRX / XT5 Forums; Just picked up a 2013 SRX and need to replace the antena. Anyone have any sugguestions where I could find ...
    Carnut_s is offline Cadillac Owners Member
    Automobile(s): 2007 CTS -V 2013 SRX
    Oct 2011
    10
    Just picked up a 2013 SRX and need to replace the antena. Anyone have any sugguestions where I could find a shorter antena? Mine isn't clearing the garage door and it's a pain to keep taking it off. Thanks
    phunter1 is offline Cadillac Owners Fanatic
    Automobile(s): 2012 SRX Luxury
    Jun 2012
    Temecula, Ca
    214
    Re: 2013 SRX After Market Antena
    Here's what I installed on my SRX. Very happy with it.
    http://visualgarage.com/Product_Overview.html
    Phil
    Marc NY's Avatar
    Marc NY is online now Cadillac Owners Connoisseur
    Automobile(s): XT5 Platinum - Red Passion
    Jul 2010
    Western NY
    1,757
    Quote Originally Posted by phunter1 View Post
    Phil
    I am not 100% sure but I would tend to believe that the OnStar signal might be compromised with that style fin on your SRX. It looks like that nice looking fin is designed for AM & FM only. It doesn't say if it is compatible with OnStar as far as I can read. It looks as if it is designed to replace short style antennas only.
    Off the Shark Fin Antenna website:
    "While designing the VG Shark Fin Antenna, we focused not only on creating a unique shape that is stylish and aerodynamic, but also in designing an antenna that would maintain AM/FM radio reception" ... we found that the VG Shark Fin Antenna performed consistently better than any stubby antenna fitted on the same car.
    How is your OnStar signal with that Shark Fin antenna? If it doesn't compromise the OnStar signal I would say then that looks like a great option to install. However, that being said, I would believe that GM would have used that same exact style (GM already uses that style on various other models) if it was properly suited for the SRX.
    Maximumkk is offline Cadillac Owners Fanatic
    Automobile(s): 2014 SRX Premium AWD - Silver Coast w/ Shale-Brownstone
    Oct 2011
    Winnipeg Manitoba
    453
    There are a couple threads on installing the fin antennas on the SRXs. See below:
    http://www.cadillacforums.com/forums...n-antenna.html
    http://www.cadillacforums.com/forums...e-08-08-a.html
    They seem to work fine, as the OnStar does not use the arial portion of the antenna. The OnStar coil is in the antenna base, only AM/FM use the arial portion.
    Max
    Jun 2012
    Temecula, Ca
    214
    I have not had an issue with Onstar working. I don't use it a lot, but when I have, it has worked fine. Hopefully, the Captian will chime in, as he has the same antenna.
    Phil
    TheCaptain's Avatar
    Aug 2009
    Moosomin Saskatchewan
    30
    3,075
    Yes, there seems to be no compromise with any bands (am, fm, XM) or OnStar even as North as we are.
    MI-SRX's Avatar
    MI-SRX is offline Cadillac Owners Enthusiast
    Automobile(s): '14 SRX4 Perf., Crystal Red Shale/Brownstone, DAP, spare
    Nov 2013
    SE MI
    662
    Quote Originally Posted by Maximumkk View Post
    In researching this issue as it relates to my pending purchase of an SRX after the first of the year I came across this. Prior model years may be different.
    From the 2014 SRX CUE Manual:
    Backglass Antenna
    The AM-FM antenna is integrated with the rear window defogger in the
    rear window. Do not scratch the inside surface or damage the lines
    in the glass. If the inside surface is damaged, it could interfere with
    radio reception. For proper radio reception, the antenna connector
    needs to be properly attached to the post on the glass.
    Multi-Band Antenna
    The roof antenna is for OnStar, SiriusXM Satellite Radio (U.S. and
    Canada only), and GPS (Global Positioning System). Keep clear of
    obstructions for clear reception.
    That being the case then Sirius/XM, OnStar and GPS might be impacted - AM/FM reception would not be affected at all.
  10. Remove Advertisements
