Rear Tag Lens Removal
Results 1 to 4 of 4
Cadillac SRX Second Generation Forum (2010-2016) Discussion, Rear Tag Lens Removal in Cadillac SRX / XT5 Forums; How do you remove the rear tag light lens...
    hwilliams555 is offline Cadillac Owners Member
    Automobile(s): SRX
    Jan 2013
    13
    st4422's Avatar
    st4422 is offline Cadillac Owners Fanatic
    Automobile(s): 2013 SRX Premium Black Ice, 2009 CTS DI Thunder Gray
    Jun 2007
    New Mexico
    337
    The fixture is removed by sliding it from left to right if I remember correctly. There is a small slot on the clear lens that makes it easier to slide with a flat blade screwdriver.
    GGMiv is offline Cadillac Owners Fanatic
    Automobile(s): 2011 SRX (Mocha Steel); 2008 SRX (Gold Mist)
    Jan 2011
    Orlando, FL
    136
    Just be careful. It is held in by tabs. One of my tabs broke off on its own. Had to have it replaced under warranty. My dealer had to order it as they don't keep them in stock. If you're still under warranty, I would let a dealer fool with it.
    rockstar143's Avatar
    rockstar143 is offline Cadillac Owners Member
    Jan 2013
    20
    Re: Rear Tag Lens Removal
    I used a plastic trim puller to push, to avoid scratching. Press the left side in to the right, then pull down from the left. Picture two little tabs that rest above the opening, the right one being flexible. It's easy.
  7. Remove Advertisements
