"Secondary" Fuel Pump on 2010 SRX
Results 1 to 8 of 8
Cadillac SRX Second Generation Forum (2010-2016) Discussion, "Secondary" Fuel Pump on 2010 SRX in Cadillac SRX / XT5 Forums; I took my SRX into the dealer today. It's been starting hard first start of the day (grinding over 30 ...
    LynnF is offline Cadillac Owners Member
    Apr 2012
    19
    Question"Secondary" Fuel Pump on 2010 SRX
    I took my SRX into the dealer today. It's been starting hard first start of the day (grinding over 30 seconds) and the "check engine light" came on on the weekend.
    I had to replace the "secondary" fuel pump.
    Just wondering if this is an anomaly or if others have had this problem.
    I have 56500 km on it.
    TheCaptain's Avatar
    Aug 2009
    Moosomin Saskatchewan
    30
    3,075
    Re: "Secondary" Fuel Pump on 2010 SRX
    65100 kms here with no issues at all with the fuel system.
    redvett94 is offline Cadillac Owners Fanatic
    Jan 2008
    MI/AZ
    455
    Do you run the tank low? Low fuel will burn out the pump in the tank. I would suspect the secondary fuel pump is the pump in the tank. I believe the primary pump is quite expensive as it produces over 1800 psi for Direct Injection.
    300:29:1 is offline Cadillac Owners Enthusiast
    Automobile(s): 2012 SRX Luxury w/NAV
    Oct 2009
    Syracuse, N.Y.
    791
    Quote Originally Posted by redvett94
    Can someone confirm this business about running the fuel tank low? How low is low? This is 1 of those things that seems to be a subject of debate.
    Jan 2008
    MI/AZ
    455
    The fuel pump is in the tank in fuel and its cooled and lubricated by gas. We had the same problem with Corvette ZR-1's and when the tank was low the dual pumps were junk.
    Keep the tank above 1/4 tank or you will have the same problem again.
    Quote Originally Posted by 300:29:1 View Post
    Apr 2012
    19
    There are 2 fuel pumps in the SRX: 1 in the fuel tank and one in the engine. I had to replace the one in the engine.[COLOR="Silver"]
    Jan 2008
    MI/AZ
    455
    D.I. engines have 2 pumps the one on the engine is the high pressure pump it produces over 1500psi. I hope it was covered under warranty.
    Quote Originally Posted by LynnF View Post
    Apr 2012
    19
    Yes. Thank goodness. That's why I wanted to know if this was a common problem.
  11. Remove Advertisements
