P0121 P0221 and P0101 codes
Results 1 to 10 of 10
Cadillac SRX Second Generation Forum (2010-2016) Discussion, P0121 P0221 and P0101 codes in Cadillac SRX / XT5 Forums; P0121 P0221 and P0101 codes Got all these Codes, I have had the MAF code before so I am thinking ...
    kanundrum is offline Cadillac Owners Member
    Automobile(s): None
    Oct 2012
    32
    97
    Got all these Codes, I have had the MAF code before so I am thinking its a bad MAF just wondering if the MAF would throw those codes as well or its something more in depth I should look at with the Throttle position Sensor
    2.8T Motor
    http://www.obd-codes.com/p0121
    http://engine-codes.com/p0221.html
    Any Hints or should I start by replacing the MAF and the TPS(Not even sure where that is) MAF was cheap enough that I ordered a new one
    TheCaptain's Avatar
    Aug 2009
    Moosomin Saskatchewan
    30
    3,075
    Re: P0121 P0221 and P0101 codes
    It's most likely the MAF. Its also easy enough to start there (which you have).
    I bet a new MAF will fix all three. (chain reaction codes)
    Automobile(s): None
    Oct 2012
    32
    97
    Awesome Thanks yea getting the new MAF in tom so lets see. The K&N Probably messed it up, or it was already messed up and the K&N didn't help. Just a simple drop in filter too
  5. #4
    TheCaptain's Avatar
    Aug 2009
    30
    3,075
    I have seen these codes thrown a lot on GM vehicles with a dirty MAF. Most usually from K & N filters...
  6. #5
    Jim_V is offline Cadillac Owners Fanatic
    Automobile(s): SRX V8 RWD 2004
    Feb 2005
    Pasadena Maryland
    153
    I have a K&N also and just spray electrical contact cleaner to eliminate any problems. Just don't touch the sensor wire let the spray do the work.
  7. #6
    Automobile(s): None
    Oct 2012
    32
    97
    Quote Originally Posted by Jim_V View Post
    DId it about 3 times now, I just got the MAF in will clear the codes replace the part and see how it starts up!
  8. #7
    redvett94 is offline Cadillac Owners Fanatic
    Jan 2008
    MI/AZ
    453
    When you get it fixed throw the K & N in the trash and use a paper filter for better filtering. Paper filters are good for 30000-50000 miles and will NOT reduce fuel economy since the engine management system will always keep the A/F ratio at 14.7. If you drive in high dusty conditions you may want to replace filter earlier.
  9. #8
    Automobile(s): None
    Oct 2012
    32
    97
    Was never looking for fuel economy, more power was always my goal. Even though it maybe hard to believe, the difference with the K&N was massive. Could hear the Turbo Spool up and a noticeable amount of power, but probably also the reason why I got the Codes. Never had an issue on any other car !
  10. #9
    Automobile(s): None
    Oct 2012
    32
    97
    Changed the MAF and got the code on again after, weird installed a brand new filter and MAF and got the P0101 code (not the others). Lets see what happens
  11. #10
    Automobile(s): None
    Oct 2012
    32
    97
    So the first time the CEL came on I got P0101, now the 2nd time I got P0121. The car is screwing with me! haha. This is even after I changed the MAF to a brand new Unit. Any ideas Folks ?
  12. Remove Advertisements
