New Headlight Assembly
Results 1 to 4 of 4
Cadillac SRX Second Generation Forum (2010-2016) Discussion, New Headlight Assembly in Cadillac SRX / XT5 Forums; When purchasing a new headlight assembly from the dealer do any bulbs come in the assembly. Any idea on the ...
    hwilliams555 is offline Cadillac Owners Member
    Automobile(s): SRX
    Jan 2013
    13
    When purchasing a new headlight assembly from the dealer do any bulbs come in the assembly. Any idea on the cost of bulbs. I am having my headlight assembly replaced under warranty (moisture in assembly). If I do not replace the low beam can I replace it without removing assembly from the vehicle. I think to replace the high beam, the signal , and daytime running lights you have to remove the bumper. 2010 SRX
    TheCaptain's Avatar
    Aug 2009
    Moosomin Saskatchewan
    30
    3,075
    Re: New Headlight Assembly
    I don't believe bulbs would be included in an assembly.
    And if you have small enough hands you don't need to remove the bumper to change the lights.
    If this is done under warranty, the dealer should be taking care of all the replacement for you...
    bwclemons is offline Cadillac Owners Fanatic
    Automobile(s): 2011 SRX Luxury
    Sep 2010
    Brighton,Michigan
    138
    You will get nothing but the plastic assembly. All of the bulbs, ballasts, if you have HID's, etc. need to be changed out of your current headlight assy. If you are doing it yourself you may want to get a used one from ebay with all of the bulbs in place. If it is really under warranty then they will do everything for you and insert new bulbs. And yes, if they are changing the whole assembly then they need to remove the front bumper cover. If you are only replacing a bulb it can be done without removing the bumper. All new bulbs will probally cost around $30 to $40. If you want a different bulb inserted for the low beams they will probally replace the ones you want, if you supply them, when they replace the headlight unit.
    adamjeeps is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 SRX Performance FWD
    Oct 2007
    1,502
    Do not pay a penny for the fix if you are covered by warranty.
  7. Remove Advertisements
