Cold start anomaly - I hope!
Results 1 to 5 of 5
Cadillac SRX Second Generation Forum (2010-2016) Discussion, Cold start anomaly - I hope! in Cadillac SRX / XT5 Forums; My wife's '11 3.0 with 10kmi usually starts immediately and drives away with no drama. This morning, temperature was in ...
    packardv8 is offline Cadillac Owners Fanatic
    Automobile(s): 2011 Saab 9-4X Premium XWD
    Apr 2012
    215
    My wife's '11 3.0 with 10kmi usually starts immediately and drives away with no drama. This morning, temperature was in the high 20s, no colder than normal. However, it cranked for quite a while, seeming to hit once in a while. It started roughly then died. On the third try, it started and seemed fine, but the "check engine" light was illuminated. One quick rev with the throttle and it went out. I suspect the O2 sensor was getting a rich reading from the prolonged cranking.
    Anyone had this experience?
    jack vines
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Re: Cold start anomaly - I hope!
    Jack,
    Sorry to hear that you all had this odd start-up on the SRX. Keep us posted if it happens again! We're happy to work with you through the process of consulting a dealership on the matter.
    Sarah (Assisting Katie), Cadillac Customer Service
    Huey Driver is offline Cadillac Owners Fanatic
    Automobile(s): 2014 ELR
    Sep 2011
    Fairfax, VA
    54
    303
    Take it in. Even though the Check Engine Light isnt on, the code is probably still there. Might show why the starting problem existed. Usually the light stays illuminated if the trouble CURRENTLY exists. The codes will stay in memory, but the light will go out, if the condition resolves itself. There might be a set period it stays in memory though. I think my old Trailblazer (OBD-II) would age out after 20 starts or something...
    Apr 2012
    215
    Started as usual this morning.
    If the problem repeats, I'll consider getting an OBDII scan.
    jack vines
    swgyoooo is offline Cadillac Owners Member
    Automobile(s): 2014 CTS Premium 3.6 AWD
    Oct 2012
    58
    I had this happen with my 12 one time. Same problems. When it did start, it was running so rough that the check engine light was flashing. I shut it off, started it again, and it was fine. Started, ran, and idled fine...no lights at all. Drove it 3,000 miles after that till I traded it in, and never another problem. I agree that codes can be stored, but I wouldnt make a special trip to the dealer if it is back to normal.
  8. Remove Advertisements
