Steering Noise - Page 5
Page 5 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 61 to 75 of 95
Like Tree12Likes
Cadillac SRX Second Generation Forum (2010-2016) Discussion, Steering Noise in Cadillac SRX / XT5 Forums; Will do If she knew what she was talking about. Hope they don't sneak another set of the same part ...
  1. #61
    Dave3727 is offline Cadillac Owners Member
    Automobile(s): 2012 SRX
    Jan 2013
    53
    8
    Re: Steering Noise
    Will do If she knew what she was talking about. Hope they don't sneak another set of the same part number. I've been driving the loaner, a 2013 SRX with 2500 miles on it. There is no squeaks or grinds and the temps have been 35 degrees and lower. So it doesn't seem to have the same issue.
  2. #62
    stevec5375's Avatar
    stevec5375 is offline Cadillac Owners Connoisseur
    Automobile(s): Formerly owned: 2010 SRX/3.0L Premium/FWD/Platinum Ice/Shale
    Jan 2010
    Austin, TX, USA
    60
    1,865
    Re: Steering Noise
    Quote Originally Posted by Dave3727 View Post
    It doesn't have the same issue "YET". Mine didn't have the problem until I hit 18K miles (2010 premium).
  3. #63
    TRARON Guest
    Re: Steering Noise
    Thanks Captain I am going to make an appointment and hopefully that will fix the problem.
  5. #64
    Jan 2013
    53
    8
    Re: Steering Noise
    Stopped by the dealer today and was told the struts where in. I asked if these were the same as they have been using? They told me its a completely new strut and they will probably be a recall issued. I was also informed that this is the forth change in design on the struts. I think I would fire that engineer by this point.
  6. #65
    adamjeeps is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 SRX Performance FWD
    Oct 2007
    1,497
    A recall would indicate a safety hazard with the struts. Do you have a part number on the new struts?
  7. #66
    classiccars is offline Cadillac Owners Member
    Automobile(s): 2012 SRX Luxury AWD
    Aug 2011
    Cleveland, Ohio
    78
    Re: Steering Noise
    My wife took her 2012 in for service yesterday. (Noise in front end when cold.)
    Ordered parts: "Upper Mounts" BUT, they said they are on national backorder. No sure on the time frame for that.
  8. #67
    Jan 2013
    53
    8
    Re: Steering Noise
    Not yet but when I pick the car up I will update if the part numbers are on the invoice.
  9. #68
    Jan 2013
    53
    8
    Re: Steering Noise
    Well I received the car back today. Good news no noise so for. Bad news is looks like they put the same part number on it again. Not a new upgraded part as was told so this is the part no# they used both times 22918669. See what happens.
  10. #69
    Oct 2007
    1,497
    Thank you for the info, and good luck on the fix.
  11. #70
    TRARON Guest
    Re: Steering Noise
    The part number for the Stabilizer Shaft Insulator (bushing) is 22741853 in case anyone is having front end noise in cold weather when going over bumps. This could be the cause of the problem. Thanks Captain for your assistance. Had mine replaced today.
  12. #71
    kanundrum is offline Cadillac Owners Member
    Automobile(s): None
    Oct 2012
    33
    97
    Re: Steering Noise
    Thanks!
  13. #72
    DTurmel is offline Cadillac Owners Member
    Automobile(s): SRX 2012 AWD Luxury
    Nov 2012
    Gatineau, QC
    81
    Quote Originally Posted by TRARON
    Thank you for sharing this....that is why I like this forum.
  14. #73
    mfdoc911 is offline Cadillac Owners Member
    Automobile(s): srx
    Mar 2012
    7
    Re: Steering Noise
    My wifes 2011 SRX has been to Permian Cadillac 5 times in the last few months for this issue Last wekk they supposedly finally repaired it per the above service bulletin. This morning 250 miles away as she entered the interstate the car began to make loud grinding and popping noisesand the steering became unstable. She is now behind a wrecker in route to the local cadillac dealer. This will be the 6th time it has been in and it has escalated from a nusiance to a safety issue. CADILLAC SERVICE SUCKS
  15. #74
    stevec5375's Avatar
    Jan 2010
    Austin, TX, USA
    60
    1,865
    Re: Steering Noise
    Quote Originally Posted by mfdoc911 View Post
    You realize that in most states if you have the car in the shop for the same problem more than 3 times, you can file under the Lemon Law?
  16. #75
    TRARON Guest
    Re: Steering Noise
    My 2010 SRX was in a lot overnight during the first cold spell this year and experienced the grinding when turning noise for the first time. Has the Strut replacement fix worked for this issue?
  17. Remove Advertisements
