HID conversion questions. 2011 Luxury
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Cadillac SRX Second Generation Forum (2010-2016) Discussion, HID conversion questions. 2011 Luxury in Cadillac SRX / XT5 Forums; I decided I'm going to do a conversion while getting my oem fogs put in and the dealer agreed to ...
    SrxNamja's Avatar
    SrxNamja is offline Cadillac Owners Member
    Automobile(s): 2012 SRX Luxury
    Oct 2012
    Midwest
    56
    I decided I'm going to do a conversion while getting my oem fogs put in and the dealer agreed to do it without damaging the warranty. I was reading through the DIY and I'm trying to figure out which one out of the 3 would be the best choice regarding the kit.
    1, Xenondepot
    2. Philipps
    3. ddmtuning
    All these are very different in price but I'm leaning towards Philips as that is oem. To the owners that have installed them, what did you choose and any issues?
    Also on the philips it has a built-in anti flicker so is the code eliminator required still and will these run constantly or just when i have the drls running?
    inspectorudy is offline Cadillac Owners Enthusiast
    Automobile(s): SRX
    Jul 2011
    697
    Re: HID conversion questions. 2011 Luxury
    I went with the Phillips and the antiflicker will not help your daytime running lights. The headlights will work but the DRL will not operate properly. I had to add the two diodes to the Phillips kit to make the DRL stay on which basically is the same as the normal low beams. HID lights have to run at full power and the DRL on our cars run at a lower power than normal. The antiflicker helps when the low beams are on to keep the voltage from flickering and causing the low beams to flicker as well. Just remember when you order to tell the company you go with that you want your low powered DRL to operate at the same power as the low beams and that your DRL operate on a lower voltage that will not run the HIDs in the DRL mode.
    mrrairai76 is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 2.0T Premium WDT, 2011 Denali WDT
    Sep 2012
    Virginia Beach, VA
    40
    208
    Personally I would do a true HID retrofit. I think you get the best light output and plus you're not blinding people when driving down the road.
    SrxNamja's Avatar
    Oct 2012
    Midwest
    56
    Quote Originally Posted by inspectorudy View Post
    Thanks for the tip! So are the code eliminators even needed for the phillips kit?
    Quote Originally Posted by mrrairai76 View Post
    its just not feasable cost wise to oem install them as they're going to cost 2k$ + labor after install. I planned on getting either 4300k or 5000k but theres no chance of blinding people as the factory housing is projected and can be used for HID regardless but placed with halogens instead of ballast/wiring + the articulating lens that the premium has.
    Automobile(s): SRX
    Jul 2011
    697
    I am not sure about the code eliminators but with the Phillips kit the low beams work fine as they are shipped. It's the DRL that cause the problem. They must have full voltage to operate as DRL with the HID bulbs. All the diodes do is keep the voltage at full power and basically keep the DRL on all of the time as low beam lights. I like the look in the daytime and at night there is no comparison to the Halogen bulbs. BTW, when I am in my garage the low beams are cut off in the vertical plane just like the old Halogen lights were. The lights form a straight horizontal line across my garage wall with no bleed over. The bottom line is that at night on unmarked outer edge line roads the HIDs are worth every penny. I also agree that going OEM on the HIDs is way too expensive to justify it because the high beams are fine with the Halogens.
    bwclemons is offline Cadillac Owners Fanatic
    Automobile(s): 2011 SRX Luxury
    Sep 2010
    Brighton,Michigan
    138
    I would do the xenon depot and add the error code eliminators with the kit. Forget any sort of relay harness. your choice of 4300 or 5000k. Both the Phillips and Xenon Depot kits have good bulbs. Stay away from the DDM Tuning as their bulbs have been failing prematurely. Do your Fogs as well. You do not need any errorcode eliminators with the fog lights.
    The halogen headlights on our cars already have the same projectors as the factory HID units but they don't have the movable headlight feature for steering wheel input or the auto leveling neither of which is needed.
    SrxNamja's Avatar
    Oct 2012
    Midwest
    56
    I decided to scratch the hid conversion until I feel a little more comfortable with the car being brand new but I'm getting my fogs installed and was wondering the most reliable bulb to give off a white light instead of the yellow on the low beams that comes stock. dont want a bulb to burn out prematurely. Even the tech was starting to be hesitent on the install that we agreed upon and drilling an additional hole in the housing.
    I was thinking of the Phillips CrystalVision Ultra Headlight Bulb that gives off a bright white instead of that annoying yellow and not too many complaints that they burn out prematurely.
    tmw
    tmw is offline Cadillac Owners Member
    Automobile(s): NONE
    Feb 2012
    41
    49
    Quote Originally Posted by SrxNamja View Post
    You might try contacting the folks at the retrofit source (google it). They were extremely helpful in putting a kit with projector together and locating a new housing for me when I converted my F150. All parts and supplies I spent $400 and it was nearly plug and play. Anyway the also pointed out a few others to me who had done the same thing i was doing so I had pictures and some how tos ahead of time.
    Might be worth a call/email to them.
    Automobile(s): SRX
    Jul 2011
    697
    The number of F-150's on the street and the number of SRX's are two different animals. The F-150 is the best selling pickup truck in the nations. I do not believe there are very many SRX HID housings on the market from any source except maybe salvage yards and that would mean an awful lot of wrecks by SRX drivers that did not include front end damage. Not likely.
    phunter1 is online now Cadillac Owners Fanatic
    Jun 2012
    Temecula, Ca
    212
    I have Phillip Crystal Vision Ultras in both my low beams and high beams. i am happy with them so far. Much better light output than the original bulbs and they are much whiter. My other car has HID's and the headlights are definitely brighter, but I can live with the Crystal Visions. I am going to install them in my fog lights as well, just haven't gotten around to it yet.
    Phil
    SrxNamja's Avatar
    Oct 2012
    Midwest
    56
    Quote Originally Posted by phunter1 View Post
    Phil
    hopefully they last long as mine are installed and ready to pick up tomorrow at the dealership since I had my fogs factory installed.
    barpuhl is offline Cadillac Owners Member
    Aug 2012
    1
    I boght the DDM Tuning kit and it worked for a week and a half for one of the ballasts to go bad. after five weeks my replacment came and it went bad in 1 hour and 15 min. I warn you not to buy from them. However, the LEDs that I got from them work just fine.
    tmw
    Automobile(s): NONE
    Feb 2012
    41
    49
    eBay, looks like a bunch of housings up there right now. All eom, but they are there. I would probably go the halogen route and convert those rather than buy the hid version and figure out the wiring for that. Would be a fun project I imagine but not so cheap. 300 for the light kit nd 200+ for the housings.
    Just a thought.
  16. #14
    SrxNamja's Avatar
    Oct 2012
    Midwest
    56
    Quote Originally Posted by tmw View Post
    Just a thought.
    I was looking at those. Only problem is majority have a broken tabs. I'm still trying to figure out how the guy that installed the volt kit on kb car stuff without drilling a separate hole for wiring. He says that everything can be tucked into the housing but majority of installs here state you have to drill the extra hole.
    http://www.kbcarstuff.com/2012-Cadil...t-s/245129.htm
  17. #15
    Sep 2010
    Brighton,Michigan
    138
    The ballast and everything else will slide into the housings, so you don't have to put any holes into the housing if you don't want to. At first I thought they would slide around but once they move into a position and get jamed in they don't move any more. So far they don't seem to be effected by any heat in the housings.
  18. Remove Advertisements
