Replacement Antenna for SRX
Results 1 to 12 of 12
Cadillac SRX Second Generation Forum (2010-2016) Discussion, Replacement Antenna for SRX in Cadillac SRX / XT5 Forums; I've checked the posts, and several people have inquired about replacing the OEM antenna for various reasons. I also need ...
    Ted K is offline Cadillac Owners Member
    Automobile(s): 2012 SRX - Crystal Red AWD Performance with DVD (Hers)
    Dec 2011
    Long Island, NY
    51
    11
    I've checked the posts, and several people have inquired about replacing the OEM antenna for various reasons. I also need to consider this as we park our cars in the garage and the OEM antenna has twice banged the bracket for the garage opener (we live in a high ranch style home and the garage ceiling is lower than ideal). I've read that the antenna has either XM or GPS wire rapped around the main antenna. I don't believe this to be true. We also own a 2011 GMC Acadia Denali with XM and onstar. I changed that antenna to a stubby one from StubbyAntenna.com 12 months ago and have had no ill effects with XM or Onstar. The OEM antenna on that car also had the wire rapped around it under the plastic/rubber coating. Interested in finding out if anyone has actually tried changing the antenna. I still have a shorter one from the car the SRX replaced and my try it before ordering to see if it causes any problems. Would really appreciate hearing from any informed sources on this. Thanks in advance.
    cvettr/cts-v's Avatar
    cvettr/cts-v is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 Infrared CTS-V
    Jun 2007
    St. Louis, MO.
    51
    821
    Re: Replacement Antenna for SRX
    I thought one person went to the body colored shark fin through aftermarket with some success.[COLOR="Silver"]
    http://www.google.com/url?sa=t&rct=j...5mnFD0Won3CTFg
    try this link
    Dec 2011
    Long Island, NY
    51
    11
    You are correct, I hadn't mentioned that. I was looking for an easier swap though without having to visit the paint shop for a car that's 5 days new. I think a screw type replacement will work fine. I'm not really sure to be honest what the wire rapped around the antenna mast is, but like I mentioned, it didn't have any ill effects with our Acadia Denali; everything still works a-okay so I'm skeptical that changing the SRX's antenna won't work. I was really hoping someone had experimented with this. I might just have to play guinea pig.
    2012SRX is offline Cadillac Owners Member
    Automobile(s): NONE
    Aug 2011
    Irving, TX
    17
    I have bought 3 shark fins from VG for 3 different vehicles and have had no issue with installation or performance...do live in the Dallas metro area though. Just provide them with your paint color code and make/model/year. Send an email if your vehicle does not come up as an option on their website. They have it painted at apparently an excellent local paint facility...my silver matches exactly including a smooth, professional finish.
    Dec 2011
    Long Island, NY
    51
    11
    What's the replacement process? Clearly it isn't a five minute swap of the screw on type. Also, where did you purchase it and what was the cost? Thanks.
    TN 2011 SRX is online now Cadillac Owners Member
    Automobile(s): 2011 SRX Premium
    Jul 2011
    Franklin, TN
    60
    19
    I did replace my antennae with a Shark Fin Antennae shortly after purchasing my 2011 SRX Premium Color Platinum Ice Metallic. The antennae works great with FM & XM with no problems. I did notice a loss of reception with AM but, I can't remember when I last used a AM radio station. No effect with Onstar at all. The installation process is simple and complete instructions came with my Shark Fin Antennae. Anyone can do this installation as it only requires installing one screw into the base where the old antennae mast was located. Then cleaning the area around the base with alcohol prior to sticking the Shark Fin Antennae with supplied tape. The antennae has been on my SRX since Aug of 2011 and washed numerous times with no signs of any separation. The color match from the vendor was a perfect match as you provide your color code from the vehicle when ordering. Please see my thread that I started about the Shark Fin. http://www.cadillacforums.com/forums...na-update.html
    Dec 2011
    Long Island, NY
    51
    11
    FYI for those that are interested. As I suspected, the XM and Onstar are NOT running through the antenna. I removed the OEM antenna completely and had no loss of XM or Onstar performance. Even called Onstar to check signal strength and everything was fine. Problem I'm having with replacement is the threads on the OEM antenna are very fine. The replacement I have from our previous car would be the perfect length but the threads are not the same. The diameter of the screw works but not the threads. It has several adapters and none work. I also tried the OEM antenna from our 2011 Acadia Denali. It has the same wrapped wire but is two inches shorter. I had to replace it on the Denali as it was too long but it would work perfect on the SRX. However, the threads are the same as the replacement antenna I have and won't screw into the srx properly. Ughhh! May have to do more research on a shark fin.
    Jun 2007
    St. Louis, MO.
    51
    821
    If you have no performance difference what about leaving off and find a cap of some sort to plug hole left by unscrewing antenna?
    Dec 2011
    Long Island, NY
    51
    11
    Well, I thought about that. WOuld like to have AM/FM though in a pinch. Ordered the shark fin from VG. Kinda pricey for an antenna, but didn't really feel I had another choice and been driving around for a week without an antenna. Worried about a downpour getting in the roof. Carrying the old one just in case, but it's my wife's car so she's not likely to get out in the rain and climb up to screw it in. Thanks for the input though.
    Jun 2007
    St. Louis, MO.
    51
    821
    good points.
    VicATS's Avatar
    VicATS is offline Cadillac Owners Member
    Automobile(s): 2015 ATS Sedan
    Jan 2016
    Georgia, USA
    30
    Concerning your antenna replacement. I need to find out if anyone has been able to reuse the GPS antenna cover when replacing the GPS antenna? I need to do this in order to keep the same paint that came with the car. This particular antenna is for a 2015 ATS Sedan. The opulent Blue will be hard to match. I see that there are four screws that seem to be securing the cover to the antenna assembly. Has anyone just swapped the covers out in order to keep the same paint that came with the car?
    btk301 is offline Cadillac Owners Fanatic
    Automobile(s): 2014 SRX Premium, Red
    Sep 2013
    157
    My old GMC Envoy had the wire wrapped around the OEM antenna. I thought it was there to prevent "whistling" sound at speed. Disrupts the air flow?? Maybe?
  15. Remove Advertisements
