Where is your idle - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Cadillac SRX Second Generation Forum (2010-2016) Discussion, Where is your idle in Cadillac SRX / XT5 Forums; Originally Posted by djmcculley My 2010 SRX-4 began to experience rough idling around 50,000 miles and is progressively getting worse ...
  1. #16
    cadigirlchicago2 is offline Cadillac Owners Fanatic
    Automobile(s): 2010 SRX Luxury
    Sep 2010
    248
    Re: Where is your idle
    Quote Originally Posted by djmcculley View Post
    My 2010 SRX-4 began to experience rough idling around 50,000 miles and is progressively getting worse now at 60,000 miles. It is getting bad where at times I think the car will stall while waiting at a stop light. My dealer suggested to clean the injectors for $210 and then monitor performance.
    Also does anyone know if there a software upgrade that might help for tuning the hp/tq curves, as I have noticed declining performance with throttle
    response and torque in the normal "drive" mode. My SRX idles around 1000rpm after settling down from 1400 rpm at start up.
    Mine does the exact same thing and I'm at 56K miles so far. I hate being at a long light because I feel like it might conk out some days. I did notice with the loaner cars they have given me, they all seem to do that, RPM's flutter. I just had my car repaired for the issue I was having with the reduced engine speed message and I was given a 2013 SRX basic with the cue system. I was very diligent to monitor the RPM’s and though it’s a new car with under 3K miles, it was rock solid steady, not 1 single flutter. I really think the 2010’s had a ton of bugs in them as well as the 11’s and some 12’s. Side note, that cue is pretty cool! Enjoyed it alot!
  2. #17
    mrperry75@gmail.com is offline Cadillac Owners Member
    Automobile(s): 2012 Cadillac SRX
    Mar 2013
    1
    My 2012 SRX has a VERY rough idle at a traffic light! It does this often and it has
    me on pins and needles in fear of stalling! i always
    Press the Onstar button for an immediate diagnostic each time. each time no
    problems are detected. If a solution is not found, i may have to trade my SRX! GLAD
    that others are experiencing the same. Hopefully, a solution will be found.
  3. #18
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Quote Originally Posted by mrperry75@gmail.com View Post
    Mrperry, I'm so sorry you've been experiencing similar concerns! I'll document your feedback for the appropriate GM teams to review, and I'm available if you decide to involve your dealership and would like assistance working with them towards a resolution. Email me anytime at Katie_Lucille@gmexpert.com for further assistance!
    Best,
    Katie
  5. #19
    junttiej is offline Cadillac Owners Member
    Automobile(s): 2005 SRX, 2011 CTS Sport Wagon
    Jun 2016
    3
    I just fixed mine with the same problem - new motor mounts did the trick. My symptoms were ran perfect, no codes, 160K miles, but an irritating vibration at 600 RPM - didn't matter if it was in P,N,R. Raise RPM to 700 and vibration goes away. This is an easy fix - definitely a DIY, you just need 13/16" shallow and deep well sockets and a ratchet that pivots at the head so that the bar can drop below parallel. Two nuts per mount come off easily - as soon as I took them off it was obvious that this was the problem. You also need to remove the cross bar above the engine so that you can raise the engine with a jack. This was easy on my 3.6L; took about an hour and cost me $200 (don't buy cheap Chinese mounts).
  6. Remove Advertisements
