Size of nut for battery cable bolt on 2010 SRX
Results 1 to 7 of 7
Cadillac SRX Second Generation Forum (2010-2016) Discussion, Size of nut for battery cable bolt on 2010 SRX in Cadillac SRX / XT5 Forums; What size nut fits the bolt in the battery cable attached to the positive terminal on 2010 SRX? Standard or ...
    morven39 is offline Cadillac Owners Member
    Automobile(s): 2013 SRX Performance FWD
    Jan 2009
    Georgia
    45
    What size nut fits the bolt in the battery cable attached to the positive terminal on 2010 SRX? Standard or metric, fine or coarse thread? I want to attach the positive lead for fog lights without disconnecting the battery since I have plenty of threads left on the bolt. Thanks in advance for the info.
    99ssconv is offline Cadillac Technician
    Automobile(s): CTS Vsport
    Sep 2011
    155
    Re: Size of nut for battery cable bolt on 2010 SRX
    find another attachment point, i have seen many people do what you want to do and you will have issues with cable not retaining tension on the battery
    Greg Franklin Guest
    Quote Originally Posted by 99ssconv View Post
    ????? Please explain. Thanks.
    Huey Driver is offline Cadillac Owners Fanatic
    Automobile(s): 2014 ELR
    Sep 2011
    Fairfax, VA
    54
    303
    SSConv, I think he is saying he will ADD another nut to the bolt, and sandwich the connection in between the original nut and the extra one (since he says he has extra threads left on the bolt). I say this without even looking at whether the battery had posts or screw-in connections.
    But, if I recall, there were a few different connection points; perhaps a buss, where you could get +12v...
    Jan 2009
    Georgia
    45
    I gave up trying to find an additional nut to fit the battery cable bolt. I just put tension on the cable connection to make sure that I didn't lose power, took the nut off, added the ring connector, replaced the nut, and retightened. By using a remote switch for the fog lights, didn't have to go through the firewall. It switches the lights on and off just fine.
    Cooper10 is offline Cadillac Owners Member
    Automobile(s): 2010 SRX
    Mar 2010
    Tampa,Florida
    75
    size of nut is either a 10mm or 12mm metric nut
    Jan 2009
    Georgia
    45
    Thanks. Will try again if connection problems arise.
  10. Remove Advertisements
