TPMS Re-Learing Tool - Page 3
Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 68
Like Tree5Likes
Cadillac SRX Second Generation Forum (2010-2016) Discussion, TPMS Re-Learing Tool in Cadillac SRX / XT5 Forums; Originally Posted by MnMs Hate to disagree with you. But the above procedure will not work on 2012. Starting with ...
  1. #31
    JimmyH is offline Cadillac Owners 10000+ Posts
    Dec 2006
    42
    37,302
    Re: TPMS Re-Learing Tool
    Quote Originally Posted by MnMs View Post
    Hate to disagree with you. But the above procedure will not work on 2012. Starting with Late 2011 Model Year GM vehicles and all vehicles build after that point will support just one TPM relearn procedure - the Dealer Procedure. Or the purchase of a learning tool. Is anyone familar with the Relearn Tool (EL-50448) sold by SPX for about $60 ?
    If that's really true, I will be pulling my tpms sensors off and putting them in a pressure vessel.
  2. #32
    dechief4's Avatar
    dechief4 is offline Cadillac Owners Member
    Automobile(s): 2012 Black Ice Premium AWD SRX
    Jul 2003
    Castle Rock, CO
    54
    69
    Tried the magnets today and they did NOT work. Now keep in mind that I purchased a tire and wheel package from Tire Rack with the tires mounted and the sensors installed. Contacted Tire Rack today and they confirmed that the correct sensors were installed. Next stop is a relearn tool.
    Unfortunately, I get to concur with you (not unfortunately I'm concurring with you - unfortunately that the magnets don't work )... I tried today on my OEM tires (what else am I going to do when it's 15 degrees and snowing?)... The magnets didn't work - and I also noticed the stems on these rims are much more 'plasticy' than the previous TPMS stems I've dealt with using the magnets. Sigh.
  3. #33
    paid4c4's Avatar
    paid4c4 is offline Cadillac Owners Fanatic
    Automobile(s): 2012 SRX/AWD Premium
    Oct 2011
    179
    I think we've gotten to the right answer. GM changed the learning technique from using a magnet to needing a special tool. https://gmspecialservicetools.spx.co...s.aspx?id=5677
    I don't think I'm going to rush right out and buy one but it is nice to finally get to the bottom of the TMPS question.
    Bill
  5. #34
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,289
    Quote Originally Posted by stevec5375 View Post
    Glad I have a 2010. But really, what a crock! The old method works just fine. Why did they need to do this? If you buy your tires from someone besides the dealer, now you'll have yet another trip to the dealer just to get your TPMS reset. Oh! Maybe they can find something wrong with you car while it's there and make even more money off of you. Now, can someone give me a GOOD reason why GM did this?
    I am in the wheel business and can not spend the time letting air out of each tire to get a reading, so several years ago I purchased a Bartec TPIS tool new from E-Bay, I probably reset 100 friends and customers car/trucks a year, takes about 10 seconds with the Bartec tool, roughly as long as it takes to remove one valve stem cap.
  6. #35
    MnMs is offline Cadillac Owners Member
    Nov 2011
    73
    Today I tested a relearn tool (ATEQ VT5) from Tire Rack on my 2012 SRX. It worked like a charm and in less than (1) minute I had all four tires relearned. It sure beats the h@ll out of letting the air out and then adding air.
    Just make sure that you press the tip of this tool on the side wall of your tire near the valve stem.
  7. #36
    classiccars is offline Cadillac Owners Member
    Automobile(s): 2012 SRX Luxury AWD
    Aug 2011
    Cleveland, Ohio
    78
    Staying with the 2012 models (Late 2011 models also) What is the part number for these new tire sensors? Someone said that it should be:
    20922900 (GM Part number) Is this correct? and will older sensors from early 2011 and before work on the 2012? I think those may have a 25920615 or 20923680 numbers.
  8. #37
    zinner's Avatar
    zinner is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-V / 2010 SRX 2.8T
    Oct 2005
    296
    I had a donut magnet that you could use on some sensor as well. Those won't work anymore?
  9. #38
    Nov 2011
    73
    Quote Originally Posted by classiccars View Post
    Take care in that the 2011 TS may not work with your 2012 OBC. I dont know the part number.
  10. #39
    NotMine's Avatar
    NotMine is offline Cadillac Owners Member
    Automobile(s): 2012 SRX Lux, with several upgrades
    Apr 2012
    Mesa, AZ
    32
    QuestionSyncing wheels after rotation?
    Owners Manual says to take it to the dealer OR talk with your dealer about a special tool to purchase. I rotate tires about every 3000-4000 miles, depending on use (it's just an OCD). Does anyone have a sync tool, probably Kent Moore, that will accomplish this? Is there another method? One of my neighbors mentioned a magnet??????
  11. #40
    TheCaptain's Avatar
    Aug 2009
    Moosomin Saskatchewan
    30
    3,075
    Merged into a thread all about tire learning tools and 2011+ SRXs with TPMS.
    Also, if it hasn't been clarified, only a tpms re-learn tool will work. (Like a GM/Kent Moore EL-50448)
  12. #41
    Dec 2006
    42
    37,302
    I just bought the tool for $80. These days, that seems dirt cheap to me.
  13. #42
    Indy_Mike is offline Cadillac Owners Member
    Automobile(s): 2012 SRX Performance Collection
    Mar 2013
    Indianapolis
    89
    Maybe somebody should start a tool rental like netflix.....
  14. #43
    NotMine's Avatar
    Apr 2012
    Mesa, AZ
    32
    Quote Originally Posted by TheCaptain View Post
    Thanks for your patience and answer. However, unless I missed something in the posts, I didn't see a definitive answer for TIRE ROTATION on a 2012 SRX, only for relearning NEW sensors. Is the tool needed specifically for TIRE ROTATION?
    Thanks again....
  15. #44
    TheCaptain's Avatar
    Aug 2009
    30
    3,075
    If you rotate your tires and want the display to show the appropriate wheel, then yes you need the tool for the vehicle to relearn the new positions.
  16. #45
    Dec 2006
    42
    37,302
    If you keep track of which wheel is where, you dont absolutely need the tool.
  17. Remove Advertisements
