What's the M by the transmission gear indicator?
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By 11RavenBlack
Cadillac SRX Second Generation Forum (2010-2016) Discussion, What's the M by the transmission gear indicator? in Cadillac SRX / XT5 Forums; I've been all over the manual and cannot find what the M is by the transmission gear indicator. The one ...
    paid4c4's Avatar
    paid4c4 is offline Cadillac Owners Fanatic
    Automobile(s): 2012 SRX/AWD Premium
    Oct 2011
    179
    I've been all over the manual and cannot find what the M is by the transmission gear indicator. The one I'm talking about is:
    P
    R
    N
    M D
    BILL
    PS: When it saves it moves the letters. The M is to the left of the D on the indicator.
    sube5186's Avatar
    sube5186 is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 SRX Premium, 3.0L AWD
    Oct 2007
    NC
    1,817
    Re: What's the M by the transmission gear indicator?
    It stands for "Manual". It allows you to shift gears manually, without a clutch, for those performance oriented drivers. You can also use it to stay in low gear for climbing steep hills or driving in snow. Once you shift into "M" by moving the stick to the left of the "D" position, you should see a number "1" just above the "M", letting you know you're in first gear. Pushing the stick forward or backward shifts gears.
    Sube
    paid4c4's Avatar
    Oct 2011
    179
    Sube, thank you for the post. I thought that might be it but was confused why the M stays there even when the car is in automatic mode. I don't use the manual option often but I do like how it works, it is really smooth almost a seamless transition.
    Bill
    11RavenBlack's Avatar
    11RavenBlack is offline Cadillac Owners Member
    Automobile(s): 2015 SRX AWD Performance; 05 Harley-Davidson Road King
    Aug 2011
    Carroll County, MD - USA
    46
    If you just move the shifter to the left and don't touch it, the car is in sport mode (on the Performance model - not sure about Premium). From the owner's manual:
    Manual Mode
    Driver Shift Control (DSC)
    Notice: If you drive the vehicle
    at a high rpm without upshifting
    while using Driver Shift Control
    (DSC), you could damage the
    vehicle. Always upshift when
    necessary while using DSC.
    allows you to shift an automatic
    transmission similar to a manual
    transmission. To use the DSC
    feature:
    1. Move the shift lever to
    the left from D (Drive) to
    M(Manual Mode).
    If you do not move the shift lever
    forward or rearward, the vehicle
    will be in Sport Mode. When you
    are in Sport Mode the vehicle
    will still shift automatically.
    The transmission may remain
    in a gear longer than it would in
    the normal driving mode based
    on braking, throttle input, and
    vehicle lateral acceleration.
    SPORT MODE ON will be
    displayed in the DIC. See Ride
    Control System Messages on
    page 5‑39. The word “sport”
    will display below the odometer.
    The gear position will also be
    indicated in the tachometer.
    Within Sport Mode there
    is a further performance
    feature called Performance
    Mode Lift Foot (PMLF) Mode.
    The feature is activated
    automatically when sports
    oriented driving is detected,
    based on cornering and on/off
    throttle application. PMLF allows
    the transmission to hold the
    current gear instead of upshifting
    when the throttle is lifted.
    2. To enter M(Manual Mode), press
    the shift lever forward to upshift
    or rearward to downshift.
    An M will be displayed in
    the DIC.
    3. To return to Sport Mode from
    M(Manual Mode), press and
    briefly hold the shift lever
    forward.
    The tachometer display on the
    instrument panel cluster will
    show which gear the vehicle is
    in. The number indicates the
    requested gear range when moving
    the shift lever forward or rearward.
    See Tachometer on page 5‑12 for
    more information.
    While using the DSC feature,
    the vehicle will have firmer,
    quicker shifting. You can use this
    for sport driving or when climbing
    or descending hills, to stay in gear
    longer, or to downshift for more
    power or engine braking.
    The transmission will only allow
    you to shift into gears appropriate
    for the vehicle speed and engine
    revolutions per minute (rpm). The
    transmission will not automatically
    shift to the next lower gear if the
    engine rpm is too high, nor to the
    next higher gear when the maximum
    engine rpm is reached.
    If shifting is prevented for any
    reason, the currently selected gear
    will flash multiple times, indicating
    that the transmission has not shifted
    gears.
    While in the DSC mode, the
    transmission will automatically
    downshift when the vehicle comes
    to a stop. This will allow for more
    power during take-off.
    When accelerating the vehicle from
    a stop in snowy and icy conditions,
    you may want to shift into second
    gear. A higher gear ratio allows you
    to gain more traction on slippery
    surfaces.
    Never Forget
    PhilC6 likes this.
    sube5186's Avatar
    Oct 2007
    NC
    1,817
    Quote Originally Posted by 11RavenBlack View Post
    Yes, you're correct. I inadvertently omitted that one step. Once you move the stick to the left, you have to move it forward to enter manual mode. That's when you'll see the gear numbers. This works the same for all trims of SRX.
    Sube
    inspectorudy is offline Cadillac Owners Enthusiast
    Automobile(s): SRX
    Jul 2011
    697
    I tried it today to see how it worked and was a bit puzzled. If you pull it to the left and do nothing with the lever it will shift normally it seems, though the gear is displayed. Does this mode serve any function? I like the manual mode and use it often in traffic and hilly areas. I am confused about the purpose of the sport mode. When I am shifting it myself it displays "Sport Mode" in the DIC and the "M" is displayed in red along with the gear selected. Does that mean that it really is in the manual mode and only shows sport mode because you have to begin in that mode? When I come out of manual mode by moving the lever to the right the DIC says sport mode off.
    paid4c4's Avatar
    Oct 2011
    179
    I tried it today also. When you pull the stick to the left it enters the "Sport Mode" which shifts a little crisper and is more in line with driving a circuit or sports type of driving. If you pull the stick to the left and then up or down you''re in the manual mode. I can tell the difference in shifting between Econo Mode and Sports. I forgot to turn off the econo mode to see the different between sports and just the regular transmission shifting, I try that tomorrow.
    Bill
    sube5186's Avatar
    Oct 2007
    NC
    1,817
    OK, there are three distinct transmission modes, TOUR, SPORT and DSC (Driver Shift Control). TOUR mode (the default) is designed so you don't feel the normal "jerk" when the car shifts gears. There's a smooth transition between gear shifts. More power assist is afforded to the steering and the suspension is softer. Essentially, TOUR mode is designed for comfort. SPORT mode is designed for performance. Switch to SPORT mode and step on the gas heavily. Notice the tachometer. The trans holds a gear much longer before shifting. When it does shift, you'll notice a prominent jerk, likes a sports car. When you want to get somewhere in a hurry or just want more excitement in your driving, SPORT is the way to go. For most situations you can just leave it in TOUR. Mileage is slightly better in TOUR as well. In DSC mode "you" shift gears just like a normal manual transmission, minus the clutch pedal. It's useful for climbing or descending hills, driving in snow and for an even more "driver involved" SPORT mode. When descending hills and driving in snow, you're using engine braking to slow down instead of depressing the brake pedal. By doing this you save wear on the brakes when descending. In snow you prevent the brakes from locking up because the low gear is what's slowing the car, not the brakes. I use this all of the time in the snow. I can drive "downhill" and never even use the brakes until I reach the bottom of the hill. Works like a charm! Remember, anti-lock brakes won't stop a car from sliding on snow or ice. They decrease the stopping distance, but the vehicle will still slide.
    TOUR: Use for normal city and
    highway driving. This setting
    provides a smooth, soft ride.
    SPORT: Use where road conditions
    or personal preference demand
    more control. This setting provides
    more “feel”, or response to road
    conditions through increased
    steering effort and suspension
    control. Transmission shift points
    and shift firmness are also
    enhanced.
    DSC: The
    vehicle will have firmer, quicker
    shifting. You can use this for sport
    driving or when climbing or
    longer, or to down shift for more
    Sube
    paid4c4's Avatar
    Oct 2011
    179
    Sube an excellent explanation of the transmission configuration on our SRX's. I would also like to hear you explanation of ECONOMY mode. So far your write-up makes more sense than the Owner's Manual, Thank You. I'll be using the sport mode in the winter as we have two large hills to transverse every time we leave the house and many times brakes only make you slide.
    Bill
    Automobile(s): SRX
    Jul 2011
    697
    Excellent write up on a subject the manual fails miserably to explain. One caveat though, having been a Porsche owner for many years our forum includes many pro drivers and they all say use your engine to brake if you need the power out of the braking situation but never use your engine to just "Save" your brakes. The idea is that a new tranny, (Wear and tear), is about ten times more expensive than a brake job. Thanks again for the clear explanation.
    sube5186's Avatar
    Oct 2007
    NC
    1,817
    Quote Originally Posted by paid4c4 View Post
    I wish I could take all of the credit, but I can't. The bottom paragraphs in my previous post are right out of the owner's manual. I just gave my personal spin on it.
    As for ECONOMY mode, I don't have it on my '10. I believe only the Turbo 2010's have that feature. It just changes a series of things (listed below) to optimize fuel efficiency. However, there's always a trade off in performance for better mileage. Play around with it and see which mode you prefer. If you notice no substantial difference in performance based on your individual driving style, leave it in ECONOMY. Why burn more gas than you have to?
    Just a word of advice to ALL owners. I would strongly suggest everyone download the PDF version of your owner's manual. You can get it right off of the Cadillac website. By simply pressing "Ctrl + F" you open up a search window that will allow you to instantly find anything in the manual using a key word. The main reason people don't want to use the hard copy of the manual is that it takes forever to find anything. Not true with the software version.
    From the Manual:
    Fuel Economy Mode
    When fuel economy mode is on:
    . The transmission will upshift sooner, and downshift later.
    . The torque converter will lock–up sooner, and stay on longer.
    . The gas pedal will be less sensitive.
    . The vehicle's computers will more aggressively shut off fuel to the engine under deceleration.
    Sube
  14. Remove Advertisements
