Air conditioner compressor always running?
Results 1 to 4 of 4
Cadillac SRX Second Generation Forum (2010-2016) Discussion, Air conditioner compressor always running? in Cadillac SRX / XT5 Forums; It feels like the air conditioner compressor continues to run after the AC is turned off......it continues to blow cold. ...
    Gilroyca is offline Cadillac Owners Member
    Automobile(s): SRX
    Jun 2011
    It feels like the air conditioner compressor continues to run after the AC is turned off......it continues to blow cold. Has anyone else experienced this? Sometimes I just want the vent only.
    Also, what does the air quality setting actually do? The manual explains how to change the sensitivity, but not what it actually does......does it just put the climate control on reticulate?
    2011 SRX Premium AWD.
    Jake2010 is offline Cadillac Owners Member
    Automobile(s): 2010 SRX - Premium - Black Raven / Titanium - Chrome Tech
    Apr 2010
    88
    Re: Air conditioner compressor always running?
    Hi Gilroyca,
    Here's a previous post about the air quality setting, hope it helps... http://www.cadillacforums.com/forums...hicle-air.html
    As far as the AC, is your "Auto" button on? if so, that will cycle the AC to keep a constant temperature. Usually if I want just vent, I turn off "Auto" and make sure the AC button is not lit.
    Jake
    Smokin' SRX's Avatar
    Smokin' SRX is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 Perf 3.0,AWD, 2011 Yukon Denali,(403HP), had 04 SRX
    Oct 2004
    NY suburbs
    1,159
    And don't forget " De-FOG" control in same Menu area. If it's on, the A/C will come on whenever it senses too much humidity in the cabin. To avoid fogging windows the A/C comes on. You can deactivate in same menu. I did.
    SS
    Automobile(s): SRX
    Jun 2011
    Thanks Jake and Smokin'.
    I checked and the auto defog was on, so I think that was why the compressor was running.......although it's just not that humid here. After I disabled the feature the compressor did not engage. Thanks.
  7. Remove Advertisements
