Gas Cap
Results 1 to 3 of 3
Cadillac SRX Second Generation Forum (2010-2016) Discussion, Gas Cap in Cadillac SRX / XT5 Forums; Anyone out there having problems with the gas cap not sealing. I keep getting check engine light , after some ...
    mjv53 is offline Cadillac Owners Member
    Automobile(s): 2010 SRX
    Nov 2010
    22
    Gas Cap
    Anyone out there having problems with the gas cap not sealing. I keep getting check engine light , after some looking around I found I can make it go away with the gas cap, off then on, thought I had it fixed then, the next day same light same fix. Is ths a problem others are having? I have a 2010 AWD turbo, if that makes any difference.
    Smokin' SRX's Avatar
    Smokin' SRX is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 Perf 3.0,AWD, 2011 Yukon Denali,(403HP), had 04 SRX
    Oct 2004
    NY suburbs
    1,159
    Re: Gas Cap
    Sorry. Common occurrance on all cars, but re-tightening cap usually clears it for good. Will post back if I find anything for ya. Meantime, hit Onstar and ask what code is coming thru. May be 2 items that need attention!
    SS
    PJ1520 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 SRX4 N*, 2004 Infinity G35 Coupe
    Feb 2010
    New England
    2,005
    Re: Gas Cap
    mjv........I wasn't going to respond to this because SS has it covered. But if it will make you feel any better, my SIL's Mercedes had this problem a week ago. The check engine light came on and he called me. It was the gas cap.
    In his case, his boss borrowed his car and refueled it before returning it to him. The gas cap wasn't screwed back down far enough, until the clicks begin. The CEL came on. He took the cap off and put it back on and the light went out, hasn't returned.
    A very common problem, also can be experienced with a bad gas cap......something to know in case your CEL keeps coming back on.
    PJ
