Weak A/C Air Vent Volume on Max Fan Speed
Results 1 to 13 of 13
Cadillac SRX Second Generation Forum (2010-2016) Discussion, Weak A/C Air Vent Volume on Max Fan Speed in Cadillac SRX / XT5 Forums; I cant direct ice cold air on my face for rapid cool downs on very hot days when car is ...
    Cooper10 is offline Cadillac Owners Member
    Automobile(s): 2010 SRX
    Mar 2010
    Tampa,Florida
    75
    I cant direct ice cold air on my face for rapid cool downs on very hot days when car is parked outside in a sunny parking lot during the day. The air vent volume on max fan speed only reaches the steering wheel. My Land Rover and BMW on max A/C fan would blow the hair off your head. Any 2010-11 SRX owner with the same concerns living in the sun belt states?
    Ponyman is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 Premium, Radiant Silver
    Mar 2010
    Holiday Island Arkansas
    63
    717
    Re: Weak A/C Air Vent Volume on Max Fan Speed
    Then you have a problem somewhere. Our 10 wil blow your hair back on max
    stevec5375's Avatar
    stevec5375 is offline Cadillac Owners Connoisseur
    Automobile(s): Formerly owned: 2010 SRX/3.0L Premium/FWD/Platinum Ice/Shale
    Jan 2010
    Austin, TX, USA
    60
    1,865
    I find the SRX fan does not blow as hard as other vehicles I've owned; nor does it cool down as quickly on hot days.
    sube5186's Avatar
    sube5186 is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 SRX Premium, 3.0L AWD
    Oct 2007
    NC
    1,817
    Quote Originally Posted by Cooper10 View Post
    Is the force of the air from that vent the same as the one on the passenger side? If not, you may have an obstruction in the duct system or a hose partially disconnected. If it is, check the Auto Fan Speed setting for the A/C. It's in the Config Menu under: Vehicle/Climate and Air Quality/Auto Fan Speed. Set it to "High".
    Sube
    stevec5375's Avatar
    Jan 2010
    Austin, TX, USA
    60
    1,865
    Here is only documentation from the manual about Auto Fan Speed:
    Auto Fan Speed
    This will allow you to select the
    automatic fan speed.
    Press the MENU / SELECT knob
    when Auto Fan Speed is highlighted
    to open the menu. Turn the knob to
    highlight High, Medium, or Low.
    Press the knob to confirm the
    selection and move back to the
    last menu.
    I did a search of the PDF manual for "automatic fan speed" and it only shows up in the previous paragraph and so there is no definition of what it actually is referring to.
    Sube, what exactly are they referring to as the "automatic fan speed" ?
    Smokin' SRX's Avatar
    Smokin' SRX is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 Perf 3.0,AWD, 2011 Yukon Denali,(403HP), had 04 SRX
    Oct 2004
    NY suburbs
    1,159
    What about the recent TSB detailing the A/C, defrost system module may need reprogramming to properly direct air to defrosters/vents? Could be that simple. Here is Willo's post..
    http://www.cadillacforums.com/forums...11-models.html
    SS
    Oct 2004
    NY suburbs
    1,159
    Steve, the "Auto fan speed" allows you to set the maximum fan speed to a moderate level, vs. full speed, when in AUTO mode, and the A/C system is attempting to regulate the temp as quickly as possible to your desired temp. Some folks object to the fan blowing full force and desire a moderate speed instead, even if that means temp won't regulate as quickly.
    I set mine to medium.
    SS
    PJ1520 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 SRX4 N*, 2004 Infinity G35 Coupe
    Feb 2010
    New England
    2,005
    SS........my wife is the impatient type, whether it is hot or it is cold outside. Even "maximum fan" is never fast enough. PJ warming the car up or cooling it down before she steps into the vehicle is her optimal "selection."
    PJ
    Oct 2004
    NY suburbs
    1,159
    Quote Originally Posted by PJ1520 View Post
    PJ
    LOL......I have a ''Queen also"! But she's worth it. And we'd best not be forgettin' it LOL!
    SS
    sube5186's Avatar
    Oct 2007
    NC
    1,817
    Quote Originally Posted by Smokin' SRX View Post
    [B]The "Auto fan speed" allows you to set the maximum fan speed to a moderate level, vs. full speed, when in AUTO mode, and the A/C system is attempting to regulate the temp as quickly as possible to your desired temp.
    Precisely!
    Steve, in your case I would suggest you at least check to see what yours is set to. If it's on medium (I believe that's the default setting), then you may want to change it to "High" to see if that improves your situation.
    Sube
    stevec5375's Avatar
    Jan 2010
    Austin, TX, USA
    60
    1,865
    I just changed mine from medium to high. We'll see if the next hot day gets the car cooled off any faster with this new setting.
    Marc NY's Avatar
    Marc NY is offline Cadillac Owners Connoisseur
    Automobile(s): XT5 Platinum - Red Passion
    Jul 2010
    Western NY
    1,706
    Quote Originally Posted by sube5186 View Post
    Precisely!
    Sube
    I believe Sube is correct... I had to leave my fan on either Auto or was it on High??? Don't recall which one it was but it seemed to do the trick to get a faster windshield defrost during the winter months.
    Oct 2004
    NY suburbs
    1,159
    Cooper10, If problem persists after above advice implemented, I just found JBSHARPE's post detailing the TSB re; A/C, Heat......... I know it says 2011, but maybe some late 2010's fell victim?
    Pls let us know.
    SS
  16. Remove Advertisements
