Aftermarket HID lights for Base and Luxury models - Page 2
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 51
Like Tree3Likes
Cadillac SRX Second Generation Forum (2010-2016) Discussion, Aftermarket HID lights for Base and Luxury models in Cadillac SRX / XT5 Forums; Here are some pictures for this procedure http://s1082.photobucket.com/albums/...X%20picturesw/ http://www.cadillacforums.com/forums...ss-lights.html...
  1. #16
    bwclemons is offline Cadillac Owners Fanatic
    Automobile(s): 2011 SRX Luxury
    Sep 2010
    Brighton,Michigan
    138
    Re: Aftermarket HID lights for Base and Luxury models
  2. #17
    2012 SRX Luxury is offline Cadillac Owners Member
    Automobile(s): 2012 Cadillac SRX
    Feb 2012
    1
    Ok, got a question. I just got a Luxury level 2012. How do I convert the low beams and high beams to HID?
  3. #18
    Sep 2010
    Brighton,Michigan
    138
    Don't do the high beams.
    I now have 36000 miles on my car and every is working perfectly. I love the conversion.
  5. #19
    TheCaptain's Avatar
    Aug 2009
    Moosomin Saskatchewan
    30
    3,075
    Yes, bwclemons is right. You should never put HID's in a non projector bulb casing. It makes it a real pain for everyone else you meet to have 3x the light output just splashed all over the place. HID's should always be in a projector style light housing.
  6. #20
    sirtronics is offline Cadillac Owners Member
    Dec 2011
    8
    I have read all of this and tried everything I can think of but I am still having problems.
    any help would be GREAT!
    2010 Luxury SRX. I installed HID lights and a relay kit I was told I needed.
    When the car is NOT started the lights come on and look great BUT when I start the car up the relay keeps clicking and the light pulse.
    I tried running lights withour relay but hen they dont come on at all.
    Am I missing something.
    thanks in ADavnce!
  7. #21
    tmw
    tmw is offline Cadillac Owners Member
    Automobile(s): NONE
    Feb 2012
    41
    49
    You didn't mentioned you installed a ballast for each HID light. Do you have those?
  8. #22
    Sep 2010
    Brighton,Michigan
    138
    A relay will not work. You need to get Error code eliminators and take out the relay. These Day time running lights use a pulse signal and that is causing the problem. They cost about $15.00. Check out DDMTuning.com or go to your favorite store that has HID lights and they will know what you need. Error code eliminators are special capacitors that smooth out the voltage going to your lights.
  9. #23
    Dec 2011
    8
    Yes Ballast is installed Sorry.
  10. #24
    Sep 2010
    Brighton,Michigan
    138
    It's not the ballast. The ballast runs the bulb, similar to a fluorescent light. You need the error code eliminators to smooth the pulsing voltage. Remove the relay. It doesn't do anything on our cars. Who ever your getting your information from is misinformed. I have 35000 miles on my car with HID's on my headlights and my fogs. My car works beautifully.
  11. #25
    Dec 2011
    8
    so do I need both the relay and code eliminators ?
    thanks again for everyones help.
  12. #26
    Sep 2010
    Brighton,Michigan
    138
    No. Remove the relay. The error code eliminators plug in just before your ballasts. They are plug and play. It will be a one minute job if you can reach your Ballasts.
  13. #27
    Dec 2011
    8
    AWESOME!!! thanks I will get them.
    any chain auto parts stores that sells this so I can pick it up today?
  14. #28
    Sep 2010
    Brighton,Michigan
    138
    I would doubt it. If you can find a store around that sells HID lights, they would have them. Usually an after market car accessory store will have them.
  15. #29
    Dec 2011
    8
    ok The code emiminators show up today.
    I disconnect the relay, connected them, turned car on and one BLEW UP one smoked!
    WTF??????
    yes i checked they were hooked up correctly pos-pos neg-neg
    besides scaring the piss out of me now I have no clue..
    help please.
  16. #30
    Sep 2010
    Brighton,Michigan
    138
    Not good. Did you disconnect the relay system you had installed completely from the system? The Error code eliminators should have been connected to normal light system, then plugged into the ballasts then to the lights. One on each side. (left and right). You will have to call or email your supplier and get another error code eliminator to replace the one that smoked. There is no reason for the eliminators to smoke normally, unless they are faulty. There should be no way to install them wrong as the plug for the lights go into the eliminators then plug into the ballasts. Have you removed any of the plugs from any of the system when you added the relays? Make sure you check all of the fuses to make sure none are blown before you start again.
  17. Remove Advertisements
