DIC - A Plethora of Messages
Results 1 to 8 of 8
Cadillac SRX Second Generation Forum (2010-2016) Discussion, DIC - A Plethora of Messages in Cadillac SRX / XT5 Forums; Most people know of the typical messages displayed by the DIC (Driver Information Center). However, few people know there are ...
    sube5186's Avatar
    sube5186 is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 SRX Premium, 3.0L AWD
    Oct 2007
    NC
    1,817
    Most people know of the typical messages displayed by the DIC (Driver Information Center). However, few people know there are tons of additional warning messages displayed under certain conditions. For example, did you know the DIC displays messages to warn you of low levels of brake fluid, engine coolant and oil? Most vehicles warn you if the oil "pressure" is low, but not the oil "level". It will also warn you of an attempted vehicle theft, turn signal bulb failure, loose gas cap and a low battery in the remote. I thought it would be informative (especially to new owners) to have all of these listed in one place. Below is the complete list, as noted on page 4-30 of the manual.
    Trip/Fuel Menu
    Trip Distance
    Average Fuel Economy
    Instantaneous Fuel Economy
    Fuel Range
    Fuel Used
    Average Vehicle Speed
    Elapsed Time
    Nav Turn-by-Turn Directions
    Speed Limit and Curve Assist
    Digital Speedometer
    Blank Display
    Vehicle Information Menu
    Unit (Metric/US)
    Tire Pressure
    Remaining Oil Life
    Battery Voltage
    Compass
    Blank Display
    Vehicle Messages
    Passenger Unbelted
    Battery Saver Active
    Low Battery
    Brake Fluid Low
    Brakes Overheated
    Step On Brake to Release Park Brake
    Release Parking Brake
    Cal (Calibrate Compass)
    Apply Brakes Before Cruise
    Cruise Set to XX
    Door Open
    Hood Open
    Power Liftgate Unavailable
    Rear Access Open
    A/C Off Due to High Engine Temp
    Coolant Level Low Add Coolant
    Engine Overheated - Idle Engine
    Engine Overheated - Stop Engine
    High Coolant Temperature
    Change Engine Oil Soon
    Engine Oil Hot, Idle Engine
    Engine Oil Low - Add Oil
    Oil Pressure Low - Stop Engine
    Engine Power is Reduced
    Fuel Level Low
    Tighten Gas Cap
    Change Fuel Filter
    No Remote Detected
    No Remote Press Brake To Restart
    Number of Keys Programmed
    Remote Left In Vehicle
    Replace Battery In Remote Key
    AFL (Adaptive Forward Lighting) Lamps Need Service
    Automatic Light Control On
    Automatic Light Control Off
    XXX Turn Indicator Failure
    Turn Signal On
    Park Assist Off
    Service Brake Assist
    Service Parking Brake
    Service Park Assist
    Service Battery Charging System
    Service Traction Control
    Service Stabilitrak
    Service Suspension System
    Service Airbag
    Service AC System
    Service Power Steering
    Service Vehicle Soon
    Service Keyless Start System
    Service Tire Monitor System
    Service Transmission
    Service Rear Axle
    Transmission Hot - Idle Engine
    Shift To Park
    Buckle Seatbelt
    Theft Attempted
    Press Brake to Start Vehicle
    Tire Learning Active
    Tire Low Add Air To Tire
    Ice Possible Drive With Care
    Turn Wiper Control to Intermittent First
    Sube
    TheCaptain's Avatar
    Aug 2009
    Moosomin Saskatchewan
    30
    3,075
    Re: DIC - A Plethora of Messages
    Quote Originally Posted by sube5186 View Post
    lol what? I wonder what conditions bring this message up!?
    sube5186's Avatar
    Oct 2007
    NC
    1,817
    If this message displays when
    attempting to activate cruise control,
    apply the brake and then try again.
    Still scratching my head on this one.
    Sube
    jcarlilesiu is offline Cadillac Owners Fanatic
    Automobile(s): 2010 Platinum Ice SRX4 Luxury Collection +Nav +RSE - 35,000M
    Nov 2009
    38
    250
    Darn, I got really hopeful. The only feature that I really miss from my BMW was the light icon that told me an exterior lightbulb was burnt out. It would light for headlights, turn signals, and even license plate bulbs. Even if a rear brake light went out, there was an additional backup bulb for "emergency stop" that would light in its place.
    Speaking of that, the emergency stop lights were nice too. If the ABS engaged, a second set of brake lights would come on to warn people behind you of heavy braking.
    Those two features I really miss. I was hopeful that one of the messages would be "Replace exterior bulb"
    stevec5375's Avatar
    stevec5375 is offline Cadillac Owners Connoisseur
    Automobile(s): Formerly owned: 2010 SRX/3.0L Premium/FWD/Platinum Ice/Shale
    Jan 2010
    Austin, TX, USA
    60
    1,865
    Quote Originally Posted by jcarlilesiu View Post
    You should return to BMW. Sounds like you really liked it better.
    Nichelle is offline Cadillac Owners Fanatic
    Automobile(s): 2010 AWD 3.0L Performance SRX (Delivered 3/19!)
    Mar 2010
    Twin Cities, MN
    138
    Interesting. I'm 100% certain I never would have noticed this. And if I did notice 'extra bright' lights, I wouldn't have associated it with heavy braking.
    TheCaptain's Avatar
    Aug 2009
    30
    3,075
    Now see, i really hate these feature's, because when changing bulbs out to LED, they draw less current and kick off the bulb out indicators. Which then requires some light hacking on the wiring for resistors to bring the current draw back up to turn the bulb out warning indicator off!
    sube5186's Avatar
    Oct 2007
    NC
    1,817
    Thread resurrected for new owners.
    Sube
  11. Remove Advertisements
