A/C Major Issue - Service Tag - Page 2
Page 2 of 7 FirstFirst 1234567 LastLast
Results 16 to 30 of 102
Like Tree1Likes
Cadillac SRX Second Generation Forum (2010-2016) Discussion, A/C Major Issue - Service Tag in Cadillac SRX / XT5 Forums; Thanks. I appreciate the help. The reason i am a bit skeptical is because I really felt like the dealer ...
  1. #16
    Esquire02 is offline Cadillac Owners Member
    Automobile(s): 2010 Thunder Gray CTS4
    Apr 2010
    48
    91
    Re: A/C Major Issue - Service Tag
    Thanks. I appreciate the help. The reason i am a bit skeptical is because I really felt like the dealer was playing hide the ball with me for several weeks on this issue and I asked multipe times but never got a straight answer on what parts needed replacement and what the actual problem was. I am not very knowledgeable when it comes to car repairs etc. and how the dealer/factory service bulletin stuff works so the help here is very enlightening. BTW, it is almost 90 here today and the A/C is working fabulously, knock on wood.
  2. #17
    GMJim's Avatar
    GMJim is offline Cadillac Owners Connoisseur
    Automobile(s): 04,06,10 SRX; 2011/14 CTS Wagon
    Oct 2005
    GM Product Development
    1,803
    Add me to the list of "steamed" owners. Blows cool at best. Cool doesn't cut it, when it's 90.
    Off to the dealership today.
  3. #18
    racingf1 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Dec 2006
    32
    I noticed, today, my A/C blows cold even when I shut it off. Blows when ventilation is on.
  5. #19
    scurling's Avatar
    scurling is offline Cadillac Owners Enthusiast
    Automobile(s): '94 Fleetwood Brogham, '94 Fleetwood, 2010 SRX 4WD, F250
    Jul 2004
    Herndon, VA.
    61
    744
    My wife just got the SRX bug and we drove the new model at the dealer. After reading through a number of these posts, I'm thinking the 2011 may be worth the wait while they work out the bugs.
  6. #20
    GMJim's Avatar
    Oct 2005
    1,803
    Low freon....i'm back to chilln'!!!!!!!!!!!
  7. #21
    ls973800 is offline Cadillac Owners Member
    Automobile(s): none
    Apr 2010
    65
    53
    Glad you got the "chillin" groove back on!
    The only question I would have is WHY was the system low on freon. The A/C is a sealed unit using "O" rings, etc to keep leaks from happening. A properly sealed unit should not lose any freon for years!
    If your A/C worked well when you first got it, and now it was low, something is leaking.
  8. #22
    TheCaptain's Avatar
    Aug 2009
    Moosomin Saskatchewan
    30
    3,075
    Freon has a dye ink in it. I'm sure they blacklighted it and would take note of any leaks.
    At least i hope.
  9. #23
    GMJim's Avatar
    Oct 2005
    1,803
    Yes they did a dye test. They said it must have come from the factory that way.
  10. #24
    Tolron is offline Cadillac Owners Member
    Dec 2007
    18
    Hmmm, same problem. At 75 deg, AC is fine; at 90 it doesn't cut it at all and left side of car is about 10 deg warmer than the right side. Dealer says it is normal in a dual zone car for the left side to lag right side when system is underperforming. Car going in on Tuesday. Hoping for quick simple fix.
  11. #25
    GMJim's Avatar
    Oct 2005
    1,803
    NOT NORMAL!!!!!! Same issue here. I am not sure mine has been fixed either. Only 75 degrees today,
    so I will be fine. In my 2006 SRX. I would have to turn it down it would be so cold. I am currently cool at best.
    The car that is....... i have never been TOO cold yet.
  12. #26
    PJ1520 is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 SRX4 N*, 2004 Infinity G35 Coupe
    Feb 2010
    New England
    2,005
    Just a word of advice. After the recharge, take the car back into the the dealer for another black light test after using the system for a couple of days. In the past for me, on another vehicle, the dye (hence the leak) was not detected by the dealer the day of the recharge when they were looking for a leak. I thought I was home free. I was mistaken.
    You don't want an a/c failure later in hot weather at the worst possible time for you, and then you find the dealer is backed up with a/c-related work.
    I made this mistake just once, with my wife's car. Guess who wound up with the car in my fleet that had a properly functioning a/c? And guess who wound up sweltering in the putrid heat for days, suffering until the proverbial "earliest appointment" day arrived?
    And try driving your car in sweltering weather, high humidity, and a rainstorm with the windows rolled up. With no a/c to strip off the humidity, the defrost unit is about less than useless clearing the inside windows.
    Just a suggestion. A pound of prevention......
  13. #27
    GMJim's Avatar
    Oct 2005
    1,803
    I got cold today (girlie man), and it was 88 degrees. There is hope.
  14. #28
    Ponyman is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 Premium, Radiant Silver
    Mar 2010
    Holiday Island Arkansas
    63
    717
    92 degrees in Southern Oklahoma today, and the wife says ours is blowing ice cold air. Unless there were some bad parts manufactured, I can't see why the SRX would be having air conditioning problems. GM has been making basically these same systems for years, and all my GM cars have always had ice cold air.
  15. #29
    GMJim's Avatar
    Oct 2005
    1,803
    You would think...............
  16. #30
    Feb 2010
    New England
    2,005
    Jim.....I think there is a TSB on chipmunks, mice, and a/c refrigerant loss. :-)
  17. Remove Advertisements
