Gas Pedel
Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Cadillac SRX Second Generation Forum (2010-2016) Discussion, Gas Pedel in Cadillac SRX / XT5 Forums; Just for my information what happens if our srx throttle sticks wide open. Will the computer shut it down?...
    lewlew's Avatar
    lewlew is offline Banned
    Automobile(s): 2010 SRX AWD PREMIUM
    Dec 2009
    OMAHA
    65
    Gas Pedel
    GMJim's Avatar
    GMJim is offline Cadillac Owners Connoisseur
    Automobile(s): 04,06,10 SRX; 2011/14 CTS Wagon
    Oct 2005
    GM Product Development
    1,803
    Re: Gas Pedel
    I would post the question here:
    http://www.toyotanation.com/forum/
    lewlew's Avatar
    Dec 2009
    OMAHA
    65
    Re: Gas Pedel
    i will not dirty my computer with a yota web site. i think we cadillac owners should be able anwser this;
    sube5186's Avatar
    sube5186 is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 SRX Premium, 3.0L AWD
    Oct 2007
    NC
    1,817
    Re: Stuck Gas Pedal
    The standard solution is this:
    1. Apply the brakes.
    2. While depressing the brakes, shift into Neutral ("N").
    3. Reapply the brakes to slow the vehicle to a stop.
    Step one is necessary to disengage the "Shift Lock", thereby enabling you to shift into Neutral. It's a rather simple process, although in a panic traveling over 100 m.p.h., one might not be calm enough to think about this. Unfortunately, (allegedly) this is what happened to that family of four killed in their Lexus in CA.
    NEVER, NEVER, NEVER turn the ignition off! This can lock the steering, obviously having catastrophic results.
    Sube
    TheCaptain's Avatar
    Aug 2009
    Moosomin Saskatchewan
    30
    3,075
    Re: Gas Pedel
    I'm pretty sure you won't have to worry about this problem, unless you are driving a toyota. But sube has the right combo in order anyway.
    lewlew's Avatar
    Dec 2009
    OMAHA
    65
    Re: Gas Pedel
    im hopeing we can get a better awnser than the obvious, i thought it was done by wire, not a cable
    RightTurn's Avatar
    RightTurn is offline Cadillac Owners 10000+ Posts
    Sep 2006
    Keep Right™
    41,011
    Re: Gas Pedel
    The answer is "no, the computer won't shut it down." If the accelerator is stuck open, the computer doesn't know that your foot isn't still on it. There are no "foot sensors" in the accelerator pedal.
    TheCaptain's Avatar
    Aug 2009
    30
    3,075
    Re: Gas Pedel
    Although, if the SRX will do it, you could just turn the key (or push the button in the SRX's case) to accessory, if it will do that. Then you retain power amenities (for a short period anyway) while killing the engine.
    Something like three presses while it's running turns it to accessory or something?
    sube5186's Avatar
    Oct 2007
    NC
    1,817
    Re: Gas Pedel
    Quote Originally Posted by TheCaptain View Post
    Yeah, only one problem. That will not only shut off the engine, but also lock the steering wheel. Retained Accessory Power (RAP) only operates the below features (page 8-18).
    These vehicle accessories can be
    used for up to 10 minutes after the
    engine is turned off:
    . Audio System
    . Power Windows
    . Sunroof (if equipped)
    Sube
    TheCaptain's Avatar
    Aug 2009
    30
    3,075
    Re: Gas Pedel
    But it still should be similar to "Run" in a normal key ignition should it not? Except after a minute or so it will cut power to the pcm/injectors and other engine functions, just leaving RAP?
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Re: Gas Pedel
    You have to turn the key all the way back to lock the wheel. If you did that, just turn it forward again to unlock. Not a big deal...
    sube5186's Avatar
    Oct 2007
    NC
    1,817
    Re: Gas Pedel
    Quote Originally Posted by thebigjimsho View Post
    What key are you talking about? My SRX has a push button start.
    Sube
    RightTurn's Avatar
    Sep 2006
    Keep Right™
    41,011
    Re: Gas Pedel
    No key.
  16. #14
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    Re: Gas Pedel
    I'd have to check and see, but GM deleted steering column locks on automatic transmission cars quite some time ago.
    I can't remember... seems like it was around 02-04 somewhere.
    Standard transmission vehicles do have steering column locks.
    The PEPS (passive entry passive start) system used on the 10 SRX will not lock the steering.
    You will lose POWER ASSIST if you turn the engine off, but you'll still have a reserve in the brakes and even so... you can still steer and push the brake, just without power assist it requires more effort, steering is easy as long as the vehicle is rolling.
    This is a pretty moot argument, the springs that GM uses in our Accelerator Pedals are pretty stout. I don't know what kind of wuss factor they built into the Yota pedals but based on the AP assemblies I have serviced it won't happen.
    Shift to Neutral or shut the engine off.... know your car and be ready is the key. If you have a car that has an ignition lock then be ready and know how to deal with it.
    Excellent question by the way, shows some thinking on the OP's part here, too bad 12 people had to die for people to worry about "what if?"
    Proof positive to me the casual attitude people take towards operating a 3,000-8,000 pound projectile.
    PS, I have accidentally engaged a steering column lock on a car while I was driving it while doing testing, not a fun experience!
  17. #15
    xrs01 is offline Cadillac Owners Fanatic
    Automobile(s): 2
    Oct 2009
    154
    Re: Stuck Gas Pedal
    Quote Originally Posted by sube5186 View Post
    Sube
    Page 8-24 in the manual discusses "Shift Lock". I must have missed the part where it says you must apply the brakes to shift from Drive to Neutral.
    Correct me if I'm wrong, but here's a question:
    With the engine running and the transmission in Drive (and you are moving and let's say you also have your foot on the accelerator), can you shift to Neutral without applying the brakes?
    I have been able to do exactly this with every other car I've owned. If it's different on the SRX, what page in the manual covers this?
  18. Remove Advertisements
