Gas tank noise - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 37 of 37
Cadillac SRX Second Generation Forum (2010-2016) Discussion, Gas tank noise in Cadillac SRX / XT5 Forums; Thanks to SS on directing me to the correct thread: I was hearing a thumping noise in the rear of ...
  1. #31
    Grizz262 is offline Cadillac Owners Member
    Automobile(s): 2010 SRX LUX
    Aug 2010
    24
    Re: Gas tank noise
    I was hearing a thumping noise in the rear of my 2010 SRX upon a gentle acceleration from a full stop. (this was not going over bumps, but mereley accelerating from a dead stop) The best way to describe it was like a shock absorber expanding (or contracting) in increments, thump, thump, thump. Not very loud, and not consitantly.
    I took it into the the dealer who said they heard the noise, and have heard it on other SRX's in the past. They advised me that GM has issued a service bulletin on the Gas Tank baffle system, and are currently working on a re-design to prevent the noise which should be out by the end of the year. Once designed, they will issue a recall.
    Anyone find a service bulletin that refers to this?
    I can scan the repair order with their comments about the SB if needed.
  2. #32
    mrl859's Avatar
    mrl859 is offline Cadillac Owners Fanatic
    Automobile(s): 2011 White SRX Performance/2011 Radiant Silver CTS-V Coupe
    Feb 2011
    Home
    411
    Re: Gas tank noise
    Quote Originally Posted by Grizz262 View Post
    I sincerely doubt that they'll issue a recall. Recalls are for safety and emissions only. They'll issue a TSB, but they won't send out notices to owners.
  3. #33
    Smokin' SRX's Avatar
    Smokin' SRX is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 Perf 3.0,AWD, 2011 Yukon Denali,(403HP), had 04 SRX
    Oct 2004
    NY suburbs
    1,159
    Re: Gas tank noise
    Quote Originally Posted by brapril714 View Post
    I had a thumping noise, traced it down to the air compressor in the rear. Pulled it out and noise went away. Going to fill up today and see if it comes back.
    Wow.......... few things going on it seems. Good info on PIT4927B. I'm still skeptical however, that ALL SRX's will be retro-fitted with a new tank/baffles. We'll see, I guess.
    CadManChris posts a very good report! But this is very different from the gas tank "thud" noise that is definitely a gas-hitting-tank-wall sound. Good to know another "fix" is available by installing some rubber strips!
    BRAPRIL 714, did you remove the Emergency Tire Inflater kit?? Good move checking for any loose items in under floor storage area! Let us know pls.
    SS
  5. #34
    algiorda's Avatar
    algiorda is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 , 2010, 2014 Luxury Raven Blk w/Ebony
    May 2008
    Tampa, FL
    649
    Re: Gas tank noise
    Folks, the gas tank is NOT even in the back of the vehicle.
    The gas tank runs from the driver seat to the rear seat from front to back and it's on BOTH sides of the drive shaft. Crawl under the car and take a look.
    I checked out this noise on my car and I attribute it to the exhaust hangers banging the exhaust pipes. They hang pretty low and have a lot of play in them.
  6. #35
    Oct 2004
    NY suburbs
    1,159
    Re: Gas tank noise
    Read your other thread. Good detective skills. Fill the tank, check for noise and be certain. An exhaust adjustment is relatively simple. I'd try some nylon tie wraps or duct tape for a 2 minute drive to be sure it's gone. Pls beware that modern exhaust systems get very HOT, in all areas!! No fun driving with bandaged hands. I burned a leg while unloading rear hatch, last summer, on the chrome tips!! Watch the kids/grandkids. ..........
    SS
  7. #36
    Oct 2004
    NY suburbs
    1,159
    Re: Gas tank noise
    SS
  8. #37
    SoCalSRX is offline Cadillac Owners Fanatic
    Automobile(s): 2011 SRX Luxury with Navigation
    Apr 2011
    132
    Re: Gas tank noise
    I've got the same problem. It was driving me nuts yesterday, but the symptoms are exactly the same as those discussed here. Subscribing...and hoping a service bulletin is released soon!
  9. Remove Advertisements
