HDD song capacity
Results 1 to 12 of 12
Cadillac SRX Second Generation Forum (2010-2016) Discussion, HDD song capacity in Cadillac SRX / XT5 Forums; My 10GB HDD maxed out at 679 songs, far short of the advertised 2,000. My music is mostly 60's short ...
    kennyfl is offline Cadillac Owners Member
    Automobile(s): 2010 SRX
    Dec 2009
    6
    HDD song capacity
    My 10GB HDD maxed out at 679 songs, far short of the advertised 2,000. My music is mostly 60's short songs. Did I get short-changed?
    sube5186's Avatar
    sube5186 is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 SRX Premium, 3.0L AWD
    Oct 2007
    NC
    1,817
    Re: HDD song capacity
    Quote Originally Posted by kennyfl View Post
    No, you didn't get short changed. That figure of 2,000 songs is based on the standard encoding bitrate of 128kbps. I have almost a thousand songs on mine and I still have space. Some are high bitrate (320kbps) MP3s. Others are 128kbps WMA files. Higher bitrate files will sound better, but take up more space. It's a trade off. I can tell you this much. If you're ripping old tracks, don't bother using a high bitrate. You'll hear no difference because the original recordings are so bad. Save the high bitrates for current stuff. They'll make the system really shine. Just FYI, WMA are supposed to have superior sound quality at the same bitrate. E.g. 128kbps WMA will sound better than 128kbps MP3. So if you really want to maximize your song count, rip to WMA.
    Sube
    Dec 2009
    6
    Thanks, but I'm just loading my regular commercial CDs.
    sube5186's Avatar
    Oct 2007
    NC
    1,817
    OK, then that tells me the default bitrate the SRX rips at is probably 320. In case I'm speaking Greek to you, check out the link below. It explains this.
    http://computer.howstuffworks.com/mp32.htm
    Sube
    sube5186's Avatar
    Oct 2007
    NC
    1,817
    The SRX is not merely "recording" your CD tracks. It's converting them to MP3 format first, then recording them to the HDD. This conversion process is known as "ripping". You can rip a CD track at various different qualities. The "bitrate" determines what quality that conversion is. Higher bitrates sound better, but take up more storage space on your HDD. The opposite is true of lower bitrates. The SRX rips at the highest bitrate to achieve maximum audio quality.
    I can show you how to double the amount of songs the HDD will hold. If you're interested, I can walk you through the process.
    Sube
    Dec 2009
    6
    I traded in an '09 Acura TL with a 12.5 GB hard drive. I had loaded 200 of my CDs onto it and there was still room left over. The SRX only took 1/4 of that amount.
    Dec 2009
    6
    If Cadillac had set it up correctly I wouldn't have to do all the extra work to get my music on the hard drive. Whatever bitrate Acura used, it still sounded great!
    Dec 2009
    6
    Is it possible to have a larger hard drive installed by Cadillac? or an outside source?
    sube5186's Avatar
    Oct 2007
    NC
    1,817
    I'm sure you could put in a larger hard drive, if you were so inclined. However, you'd completely void the warranty. Relax. There's a much easier way. All you have to do is rip your CDs on a computer using Windows Media Player (or similar program). Select the bitrate you want. I would suggest WMAs at 128Kbps. Make sure you select "Unprotected". Then, put the converted files onto a thumb drive and record them onto the HDD from that. The end result will be exactly the same, except of course you'd be able to fit more songs. This is how I transferred my music. I did it like that because I didn't know what bitrate the SRX rips. I didn't even bother called Cadillac to ask. As soon as I would have mentioned "bitrate" they would have began scratching their heads.
    Apparently, Cadillac chose audio quality over capacity. A true audiophile wouldn't really fault them for that.
    Sube
    mw1862 is offline Cadillac Owners Member
    Automobile(s): 2010 SRX (FWD Performance Model)
    Oct 2009
    Orange County, SoCal
    92
    By pushing the menu button in CD HDD mode the memory used gauge appears accross the bottom of the screen. I have 600 mp3's on my hard drive and this gauge only shows about 25% usage. Perhaps your HDD is defective. I am experiencing the initial "skipping" all of the time now that many on this board have talked about. Something is screwy with the hard drives. You may be lucky if you can get them to replace yours now. I am just waiting for mine to crash so I can replace it. I don't know who the supplier is for the SRX HDD but they may have an equipment quality issue.
    Please share your outcome. Thanks.
    Dec 2009
    6
    I brought the problem up with my dealer's customer support rep and she suggested I call Cadillac Customer Support. I was on the line with a kid for 30 minutes who didn't know his ass from his elbow and tried to tell me the HDD only had 1.1 GB of music storage. After explaining to him that the HDD navigation system was advertised to have 10 GB of music storage he said he had to transfer me to the Navigation System Department. I was on hold for another 10 minutes and finally hung up.
    I wonder what could have possibly caused GM to go bankrupt.
    RightTurn's Avatar
    RightTurn is offline Cadillac Owners 10000+ Posts
    Sep 2006
    Keep Right™
    41,011
    Gee, guess you shoulda kept the Acura.
  15. Remove Advertisements
