Page 1 of 3 123 LastLast
Results 1 to 15 of 40
Thread: New Recall SRX
    Sep 2004
    458
    New Recall SRX
    WASHINGTON - General Motors Corp. said Friday it was recalling about 313,000 passenger cars and crossover vehicles to fix a fluid leak that could lead to the driver losing control of the vehicle.
    The recall involves 275,936 vehicles in the United States, including the 2005-2007 Cadillac CTS and STS sedans, 2005-2007 Cadillac SRX crossovers, and 2006-2007 Pontiac Solstice and the 2007 Saturn Sky convertibles. About 38,000 additional vehicles are under recall in Mexico, Canada, the Middle East and Asia, GM said.
    GM said the seal on the rear axle pinion, which provides power to the wheels, does not meet all specifications and could leak fluid. GM spokeswoman Carolyn Markey said the leak could lead to the drivewheel jamming up and locking while the vehicle is being driven, possibly causing the driver to lose control.
    SYROB
    The Wrench is offline Cadillac Owners Enthusiast
    Automobile(s): '08 SRX V6
    Oct 2007
    Dallas
    542
    Re: New Recall SRX
    Interesting; my last two GM cars, 2000 Corvette and 1987 Corvette, both had the same problem. Seems they couyld figure it out in 20 years.
    DG
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    Re: New Recall SRX
    As I mentioned somewhere else, I saw a bulletin that was released on this Monday, I have not heard of a recall.
    It is possible but don't rush in to the dealer! They may not know about it yet.
  5. #4
    mjk is offline Cadillac Owners Fanatic
    Automobile(s): 04 srx v6
    May 2006
    RICHMOND, VA
    38
    203
    Re: New Recall SRX
    do I understand it correctly that 2004s are not affected??
  6. #5
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    Re: New Recall SRX
    I seem to recall the header of the letter reading 2005-2007.
    No way to know for sure until it hits print though.
  7. #6
    Stoopalini's Avatar
    Stoopalini is offline Cadillac Owners Fanatic
    Automobile(s): 2006 V6 RWD SRX | 2005 Red CTS-V
    Sep 2007
    Liberty Hill, Texas (Austin)
    117
    Re: New Recall SRX
    MSNBC is reporting '05 - '07 as the recall years. Was the rear different in the '04s?
    http://www.msnbc.msn.com/id/22363215/
    Thomas.
  8. #7
    EXPSD is offline Cadillac Owners Member
    Automobile(s): 2010 CTS Sportwagon W/Performance package, 3.6 DI
    Apr 2007
    Webster, NY
    63
    Re: New Recall SRX
    Had the problem and had it repaired 2 months ago.
  9. #8
    Maxrx7 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Aug 2007
    3
    Re: New Recall SRX
    Quote Originally Posted by EXPSD View Post
    ditto
  10. #9
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    Re: New Recall SRX
    The parts that are available to fix this concern now are different than the parts that were available 2 months ago.
    You'll probably get a letter, don't think it is handled.
  11. #10
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    Re: New Recall SRX
    On the right is the new design yoke and seal. On the left is the old style.
    This is the repair as outlined by the newest TSB.
    I suspect the recall will use these same parts. I also suspect it will be an inspect and replace type of recall.
    It looks to me as though the issue is dirt getting trapped inside the seal lip causing premature failure.
    They seem to be putting a great deal of emphasis on keeping the dirt away from the sealing surface on this improved design.
    The rear pinion update is similar.
    Unless you have gotten this done since December 17th you probably have the original design seal on the left.
  12. #11
    Sep 2004
    458
    Re: New Recall SRX
    So does this affect gear alignment in any way when done, if yes will cause a host of new problems anytime you tinker with that stuff.
    SYROB
  13. #12
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    Re: New Recall SRX
    The only real issue as far as the gears would be that if the installing tech doesn't torque the pinion nut properly it will overload the pinion bearings and ruin them. I guess if it was undertorqued it might cause some backlash issues and possibly damage the differential case and/or pinion gear.
    The Service Manual has procedures the installer should follow.
    This includes the use of med. strength loctite on the pinion nut to prevent it from backing off and loctite on the drive shaft bolts.
  14. #13
    louisn's Avatar
    louisn is offline Cadillac Owners Fanatic
    Automobile(s): 2004 srx V-8 awd
    Jan 2005
    arkansas
    482
    Re: New Recall SRX
    ewill3rd, good info. Thanks!!
  15. #14
    GMJim's Avatar
    GMJim is offline Cadillac Owners Connoisseur
    Automobile(s): 04,06,10 SRX; 2011/14 CTS Wagon
    Oct 2005
    GM Product Development
    1,803
    Re: New Recall SRX
    I noticed a small puddle on the garage floor. I can't complain. First trip to the dealer since I had the vehicle.
    Almost one year, 28K miles.
  16. #15
    GMJim's Avatar
    Oct 2005
    1,803
    Re: New Recall SRX
    Took my 06 in yesterday for leaking rearend.
    They replaced both pinion & axle seals in the rear & pinion seals in the front.
    He said that will hold me over until they decide a recall.
    New washer pump. HDLP washers & rear window washer quit working.
    This is the best ever!
    Customer states wind noise on passenger side, top of weatherstrip.
    Tech reply:
    Align Drivers door
    Me, the service writer & the tech got a good laugh oughta that.
    what ever he did, it fixed it!
  • You may not post replies
