2005 SRX no start
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, 2005 SRX no start in Cadillac SRX / XT5 Forums; I recently purchased a 2005 SRX. The engine will turn over and hit once and sounds noisy, but after it ...
    Bro. Perry is offline Cadillac Owners Member
    Automobile(s): 2005 stx
    Jul 2014
    9
    I recently purchased a 2005 SRX. The engine will turn over and hit once and sounds noisy, but after it tries to start once it only cranks over and over. Replaced a cam sensor that did not fix it. Pulled the intake, most of the bolts were loose. What could be causing this not to start?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,870
    Re: 2005 SRX no start
    An SRX is quite different from an XLR. Let's move this to the proper model/year forums.
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    81
    2,798
    Need air, spark and fuel to run. Car now has set DTCs which will help in diagnosing what's wrong. Let us know what they are and we'll go from there.
    Been fixin' cars for 74 years
    Jul 2014
    9
    Pulled the intake and replaced gaskets and a new crank sensor. Still does not start. Po code 340,341 and 391 are set any ideas would be appreciated. Checked fuel pressure it is almost 50 pounds.
    Pinhauler is offline Cadillac Owners Fanatic
    Automobile(s): 06 v6 SRX
    Sep 2009
    Troy / Mi.
    64
    334
    I know it sounds crazy but did you change the spark plugs ?
    Jul 2014
    9
    No I did not change the spark plugs, but I took all of them out and ran a compression test and found no compression on any of the cylinders. I bought this vehicle from the bank it was a repo. I was hoping to get lucky and it be a simple fix. What would cause a engine with 114,000 miles to go bad this soon?
    Sep 2009
    Troy / Mi.
    64
    334
    So - I'm not sure if were talking v8 or v6 . If it's the v6 , they never checked the oil and drove it with no oil !
    Jul 2014
    9
    This is a 4.6 Northstar code a LH2
    calif phil is offline Cadillac Owners Enthusiast
    Automobile(s): 2014 ATS
    Jan 2013
    Kansas
    512
    I would spray some starting fluid in the intake and try and start it. If it runs on the starting fluid then you know you have a fuel delivery problem.
    SFVetteman's Avatar
    SFVetteman is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 CTS 3.6 Premium, 1999 Corvette,370 RWHP & other mods
    Jul 2011
    San Francisco
    1,116
    Your DTC's are all camshaft position sensor codes. It seems unlikely to me that 3 cam sensors would go bad at once so, I would look for a bad timing chain tensioner or stretched timing chain.
    Bill
    Jul 2014
    9
    Would that effect both sides. I have never heard of a engine with no compression
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    81
    2,798
    Have someone watch crank pulley while trying to start. Is it turning? If it is, you have toast for an engine.
    Jul 2014
    9
    I don[t understand, why would watching the crank turn over make a difference/ Is there a post on how to replace and remove a northstar in our srx. I have removed the left valve cover and the chain is intact and it does not look as if it has jumped time. I guess i will take off the other valve cover and strip the front of the engine to see the chain assembly. This thing is hard to work on.
  16. #14
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    81
    2,798
    You said you had NO compression. If the crank doesn't turn, you won't have any compression. Just because the starter runs doesn't necessarily mean the crank is turning.
  17. #15
    JayTF1 is offline Cadillac Owners Fanatic
    Automobile(s): NONE
    May 2012
    36
    144
    Quote Originally Posted by Bro. Perry
    Amen Bro. Perry
  18. Remove Advertisements
