Fuel pump (?) noise - right rear
Results 1 to 7 of 7
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Fuel pump (?) noise - right rear in Cadillac SRX / XT5 Forums; I've recently noticed a noise coming from the rear when one of the right passenger doors are open on my ...
    bendebusk's Avatar
    bendebusk is offline Cadillac Owners Fanatic
    Automobile(s): 2005 SRX
    Oct 2013
    NW Italy
    148
    I've recently noticed a noise coming from the rear when one of the right passenger doors are open on my 2005 V6 SRX. It kind of sounds like a small cigarette-powered air compressor running. Not sure if it's new or if it's been there for awhile and I just haven't noticed. The car runs fine with no warning lights/messages.
    If I recall from the build sheet, there is no special air suspension option on this car. Could the noise possibly be an indication that the fuel pump is wearing out? If so, what am I looking at as far as cost?
    [Because I'm in Europe, I'm kind of dreading any response I receive!]
    glake89's Avatar
    glake89 is online now Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    81
    2,799
    Re: Fuel pump (?) noise - right rear
    Fuel pump is in the tank, and no, you don't want to have to deal with that. Suggestion, keep fuel level above 1/4, pump is cooled by the fuel. Maybe it's related to the LG system, about which we know nothing!
    Been fixin' cars for 74 years
    bendebusk's Avatar
    Oct 2013
    NW Italy
    148
    Thanks, Glake!
    I also thought of the LPG angle and wondered if I should have been running the car more often on regular gasoline instead in order to lubricate the fuel pump. May be too late now, since it's making the noise even when I select the regular fuel tank. Wish I'd thought of that sooner!
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    81
    2,799
    Unless it was disabled the cars pump should run whenever ignition is in 'run' position.
    bendebusk's Avatar
    Oct 2013
    NW Italy
    148
    If I were engineering an LPG system, I think I would include a fuel pump shutoff circuit for when it wasn't needed. But I hear the same noise whether the car is running on gasoline or LPG, so I just don't know.
    I guess I need to go out to the parking lot and crawl around under the car a bit and try to isolate from where the noise is coming. I miss having a driveway/garage to work in!
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    81
    2,799
    All you need to do to see if it's the fuel pump is pull the fuse. When you then turn the ignition switch to 'on' , the pump won't run.
    bendebusk's Avatar
    Oct 2013
    NW Italy
    148
    Good easy tip...thanks Glake!
  10. Remove Advertisements
