2008 SRX locking/unlocking issues
Results 1 to 6 of 6
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, 2008 SRX locking/unlocking issues in Cadillac SRX / XT5 Forums; My passenger rear door seems to only lock and unlock after it has been sitting for a while. If I ...
    eddieb_21 is offline Cadillac Owners Member
    Automobile(s): 2008 SRX
    Jun 2014
    1
    My passenger rear door seems to only lock and unlock after it has been sitting for a while. If I drive it and then put the car in park all 3 other doors unlock except for that 1. I have checked the fuses and nothing is wrong. Any ideas?
    Thanks in advance,
    Ed
    glake89's Avatar
    glake89 is online now Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (gone), '07 GXP, 2010 li'l red wagon 3.6
    Aug 2010
    Interlochen,MI
    82
    2,945
    Re: 2008 SRX locking/unlocking issues
    You may have a 'B' DTC which would more closely identify the cause, but since both rear doors go through the same modules the problem is likely in the latch itself. Might just need a little lube.
    Been fixin' cars for 74 years
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,722
    Hello eddieb_21,
    I apologize you are experiencing this with your rear doors. I am not sure if you are looking to make this repair on your own or work with your dealership. If the dealership route is one that you plan on taking, please reach out via private message with your full contact information, VIN, current mileage, and preferred dealership, and I would be happy to assist with setting you up with them.
    Sincerely,
    Jonathan A. (Assisting)
    Cadillac Customer Care
    JayTF1 is offline Cadillac Owners Fanatic
    Automobile(s): NONE
    May 2012
    37
    144
    Some owners have had to replace the door actuator which ceases to fire properly. I've got a similar issue with my rear passenger door, but only when it's 90deg. outside.
    As Glake mentioned its only on one side, likely making it a mechanical issue.
    The Wrench is offline Cadillac Owners Enthusiast
    Automobile(s): '08 SRX V6
    Oct 2007
    Dallas
    542
    Amazingly, I have exactly the same issue with my '08 - right rear lock will function a couple of times in a row, then fail to pull all the way up or down. Power is getting to it, you can see and feel it try to move.
    I took it out and wiggled the wiring and pulled the lock up and down many times. It has the same failure mode when just hanging by the wires - works a couple of times when cooled off, but then fails to pop all the way. Allowing it to cool a few minutes gets it to work again for a pass or two.
    Got to be the solenoid in the switch, since both rear doors are wired in parallel, and you can see it's getting power. Tried to take it apart, but the mechanism is riveted together. Bought a used one on Ebay, should be in tomorrow. I'll report results. Not really difficult to replace, but you will probably destroy the moisture barrier liner unless you are very careful. If you want to attack it, I can walk you through the panel removal and lock switch replacement.
    DG
    Oct 2007
    Dallas
    542
    Just to follow-up; I received and installed the used lock. Works great. I did a little research, and discovered it's pretty common in GM trucks. The culprit seems to be the little motor built into the lock mechanism that runs the lock up and down (not a solenoid as I thought, but a little DC motor). The Chinese-made motors wear and begin to stick after awhile. Can't easily get in to check or clean the motor because the mechanism is riveted together.
    A hint when removing the door panel, be very careful to not tear up the moisture barrier sheet; mine had been off previously to repair a little ding, and it tore up pretty bad when I removed it the 2nd time. Bought a new one from an on-line supplier for $20 and all is new again. part # 15252551 for Rt Rear.
    Oh, on a positive note: the door panel design and execution on this car is the best I have ever seen, even beats Mercedes. Materials are really good, there's a quick-disconnect electrical connector, and the push pins are totally reusable. I'm really really impressed. Give that guy a raise.
    DG
  9. Remove Advertisements
