Is there a way to reset the EBCM on 2005 Cadillac SRX without a computer???
Results 1 to 7 of 7
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Is there a way to reset the EBCM on 2005 Cadillac SRX without a computer??? in Cadillac SRX / XT5 Forums; Hi, I had the ABS and TC light come on in my truck when my mother had an accident with ...
    jaysevilla4 is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac SRX V6 AWD
    Jun 2014
    30
    Hi,
    I had the ABS and TC light come on in my truck when my mother had an accident with the vehicle. The mechanic that had checked the vehicle mentioned that the ground wire for the module was severed and that the readings he had for voltage were incorrect. So he had replaced the wiring and the lights still did not go off. He said that the module needed to be reset most likely but that he did not have the equipment to do so. I called the dealer and they wanted to charge me $200+ for the flash however they also wanted to diagnose themselves and wanted to charge me $90 for that as well. The mechanic before told me that he's very confident that all it needs is to be reset however he wasn't sure if there was any other way to do so without the computer but recommended me to ask on a cadillac forum as he knows that there are some cars that is possible to do without one. So I figured I'd ask here.
    Any advice or ideas would be greatly appreciated.
    Thanks,
    Jay
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (gone), '07 GXP, 2010 li'l red wagon 3.6
    Aug 2010
    Interlochen,MI
    82
    2,945
    Re: Is there a way to reset the EBCM on 2005 Cadillac SRX without a computer???
    I can't find anything about 'resetting' the ECBM unless it has been replaced. My opinion, if you have the ABS and TC lights on, you also have several DTCs; we need to know what those are. Generally the lights go off after several driving cycles without the faults present or can be turned off with any good scan tool. The accident may have jarred something loose that you haven't found yet.
    Been fixin' cars for 74 years
    Jun 2014
    30
    So oddly enough, when I used a scan tool to see if any codes were firing, it said there was none. I'm not sure what other options I have. Is there a way to flash the module without a computer?
    dkozloski's Avatar
    dkozloski is online now Cadillac Owners 10000+ Posts
    Jul 2004
    Fairbanks, Ak
    28,313
    Did you use an el-cheapo engine code only scanner or a high end scanner that will read the body codes you're interested in?
    Don't mess with Binky Bear!
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,559
    To flash the module you need a tech 2 or potentially the MDI tool that Gm is using now could do it. Along with either a paid subscription to tis2web or a copy of the older DVD based tis2000 and appropriate hardware based security token which may or may not contain the software you are needing. Also if there weren't any updates issued there likely won't be a copy of the software to flash it to your car.
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,622
    Find an independent shop with the right tools and see what their price is.
    rlh6805 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 SRX AWD 3.6L
    Jun 2012
    51
    326
    Quote Originally Posted by conedoctor View Post
    Good advice here!! A good independent shop will have the proper tools and will be able to diagnose the issue properly.
  10. Remove Advertisements
