Results 1 to 10 of 10
Thread: Cadillac SRX AWD 4.6 v8 Sport Drive train vibration
    ChefKoepp is offline Cadillac Owners Member
    Automobile(s): None
    Jun 2014
    None
    6
    Exclamation Cadillac SRX AWD 4.6 v8 Sport Drive train vibration
    I have a 2008 SRX v8 sport. Love the car, but have a drivetrain vibration that so far no Cadillac mechanic has figured out. I have replaced the Tranny Mount, and still feeling the vibration slightly in the stick shift, gas pedal and ever so slightly in the steering wheel. I have been told it may be carrier bearing, or the rear differential Flex Disc Coupler. I did have violent movement of the stick shift when breaking and I replaced the rear brake disks and it seemed to eliminate the issue at breaking, but from 40 to 80 I really feel the vibration. I can see the side view mirror blur when driving due to the shaking of the vehicle. I have had new tires put on the car, and also had the road force balance. The vibration seems too fast to be the wheels or half shafts. it is too high a frequency. I do notice many rubber couplings on the drive output shafts and thinking they may be at issue. I need to stop throwing money at the issue. I have had two dealerships diagnose but they just did an undercarriage look, they did not attach any monitors.
    Paul_P's Avatar
    Paul_P is offline Cadillac Owners Member
    Automobile(s): 2007 SRX 4 V6
    May 2014
    Townsend, Mass
    14
    Re: Cadillac SRX AWD 4.6 v8 Sport Drive train vibration
    How many miles? What about the propeller shaft support bearing. This may require replacing the drive shaft if a dealer is doing the work.
    Mar 2010
    Detroit, USA
    12,709
    Quote Originally Posted by ChefKoepp View Post
    Hello ChefKoepp,
    I am very sorry that you are experiencing this vibration issue and I understand how frustrating the lack of a resolution must be. I can see that you are reaching out to the forum for advice, but I would like to offer my assistance should you want to head back to a dealership. Please feel free to PM me and we can discuss this issue further.
    Have a great night,
    Austin J.
    Cadillac Customer Care
  5. #4
    Automobile(s): None
    Jun 2014
    None
    6
    the car now has 88K miles. I have done the sequence of vibration test at the dealer and their answer is to balance the driveshaft using a radiator hose clamp and moving it around on the shaft till it settles out. I will double check the carrier bearing. Where can I purchase a new driveshaft that is NOT at the dealer. They want 800 for a new one. I also see that the front output shaft has a rubber coupling too. It may be out too I guess. You can not just purchase a new flex disk from the dealer, you have to buy the whole shaft.
    I have been now to three different dealerships and no resolution. I'm not going to keep paying for diagnosis when they cant figure it out. It's obviously drive shaft. I have new tires, motor mounts transmission mounts and breaks and rotors too. This is chasing and they should be more expert than that. I have worked with Jeff over at Cable Dahmer in Independence MO. He seems to be the most helpful but I will pay for the fix, but no more paying for diagnosis.
  6. #5
    glake89's Avatar
    glake89 is online now Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (gone), '07 GXP, 2010 li'l red wagon 3.6
    Aug 2010
    Interlochen,MI
    82
    2,906
    A complete and thorough vibration analysis can be a long and expensive proposition. Having said that, here are 2 tests you can do yourself that may help isolate the cause. From the SM-"Accelerate the vehicle to a speed higher than the speed at which the disturbance occurs.
    Important: If the vehicle is equipped with a continuously variable type automatic transmission, let the vehicle coast to a stop before shifting back into gear.
    Shift the vehicle into NEUTRAL and allow the vehicle to coast down through the disturbance range.
    Does the disturbance still occur while coasting-down in NEUTRAL?
    Go to Step 19
    Go to Step 18
    18
    Select a smooth, level road and slowly accelerate the vehicle up to the speed at which the disturbance occurs.
    Decelerate and safely downshift by one gear range.
    Operate the vehicle at the same VEHICLE SPEED at which the disturbance occurs.
    Does the same disturbance still occur while going the same vehicle speed in a lower gear range?"
    I also note the flex couplers are shown as separate parts in the SM but not in the dealer parts lists. Check out Revshifts' ad (on right side of forum page), they have them.
    Been fixin' cars for 74 years
  7. #6
    Automobile(s): None
    Jun 2014
    None
    6
    We have now replaced both motor mounts, and the vibration is still there. I have been told that maybe the propeller shaft may not have been aligned correctly when reinstalled after the engine was removed. We are going to try to realign the propeller shaft tomorrow.
  8. #7
    rdgfx3 is offline Cadillac Owners Member
    Automobile(s): 2006 V6 RWD SRX
    Aug 2014
    Rowlett,Texas
    54
    21
    I'd like to know how a propellar shaft alignment procedure is performed. I'm having an issue just like this right now.
  9. #8
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,906
    If you are willing to do this- (from the SM), I'll post the rest.
    Important: The runout of the propeller shaft to be balanced and the runout of the components that the propeller shaft mates to must be within tolerances before an attempt should be made to perform this procedure.
    Adjustment Procedure
    Notice: Do not depress the brake pedal with the brake rotors and/or the brake drums removed, or with the brake calipers repositioned away from the brake rotors, or damage to the brake system may result.
    Raise and support the vehicle; ensure that the drive axle, or axles are supported at ride height - vehicle body supported by suspension components. Refer to Lifting and Jacking the Vehicle in General Information.
    With the tire and wheel assemblies, and the brake rotors and/or brake drums removed from the drive axle(s), start the engine and turn OFF all engine accessories.
  10. #9
    Automobile(s): None
    Jun 2014
    None
    6
    Update:
    Tires need to be Road force Balanced. (Most of the problem) Drive shaft was replaced and also the bushings in the rear differential were replaced and it is tight again.
    Now im at 118K and I'm having a bucking issue. Thinking that might be tranny or transfer case chain. engine is running smooth so not a backfire.
  11. #10
    Pinhauler is offline Cadillac Owners Fanatic
    Automobile(s): 06 v6 SRX
    Sep 2009
    Troy / Mi.
    64
    369
    You should start a new thread on the bucking issue . Hard to find help here .
  • You may not post replies
