Persistent P0300, P0171, P0174 codes on 04 SRX V8 AWD.
Results 1 to 9 of 9
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Persistent P0300, P0171, P0174 codes on 04 SRX V8 AWD. in Cadillac SRX / XT5 Forums; My wife's 04 SRX has a 170k miles on it. It had been running fine. It has started persistently pulling ...
    arapley is offline Cadillac Owners Member
    Automobile(s): 2004 SRV V8 AWD
    Nov 2010
    47
    3
    My wife's 04 SRX has a 170k miles on it. It had been running fine. It has started persistently pulling the p0300, p0171 and P0174 trouble codes. If the codes are cleared, they return within the first couple miles of driving. Hot, cold..it does not matter, The car seems be idling a little rougher than normal, has more engine pinging noises than usual during driving, but the overall performance seems to be fine. I assume the p0300 code is likely caused by the other 2 codes. The last time I saw the p0171 and p0174 codes years ago it was because the intake manifold bolts had come very loose. However this time all of the intake manifold bolts to the block are snug, The car has had the plugs replaced around 150000 miles and the airfilter is also clean. I am not sure what is a causing these trouble codes, if anyone has had similar issues and resolved them, I would appreciate any suggestions on what to look for.
    Thank-you
    Sheepish is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Cadillac SRX V8 AWD
    Aug 2012
    Kalamazoo, MI
    48
    328
    Re: Persistent P0300, P0171, P0174 codes on 04 SRX V8 AWD.
    check the throttle body pigtail wiring. I had one that was broken inside the casing giving me intermittent contacts and frustrating the hell out of me until I found it. wiggle it around and see if it kicks more codes.
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6, 07 Solstice GXP
    Aug 2010
    Interlochen,MI
    81
    2,787
    171 & 174 are lean fuel, both banks, so look for vacuum leak between MAF and intake manifold as well as both PCV lines which may have become brittle.
    Been fixin' cars for 74 years
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    Haven't the v8's had an issue with the intake bolts coming loose? Kinda sounds like that could be the issue given those codes or mass air flow sensor.
    REALTORBENJAMIN's Avatar
    REALTORBENJAMIN is offline Cadillac Owners Fanatic
    Dec 2012
    275
    Quote Originally Posted by repnatl
    What's the torque specs on the intake bolts for the NS v8?
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    81
    2,787
    89in/lb
    Nov 2010
    47
    3
    Thank-you for the suggestions. I found that a vacuum line at the rear of the engine connecting the intake to the valve cover had decayed and had a large hole in it. I replaced that rubber elbow piece and cleared the codes. . This fixed it for a while but the codes came back again after about 50 miles. Must have 1 or more leaks somewhere else. The steering pump failed earlier in the week.. I ended up taking the car to the shop to be fixed,
    Dec 2012
    275
    Checked my intake bolts... Loose enough that when I tap them with a screw driver they move around.
    steffhimes is offline Cadillac Owners Member
    Automobile(s): 04 SRX Northstar AWD
    Jan 2016
    38
    04 cadillac srx v8 awd, I changed the throttle body first and discovered the wiring and replaced it with a new plug for $$$, but no limp home mode of like 5 mph. I changed the plug and the oil sending unit at the same time for the same reason; the plug was crap, missing insulation on wires.
  12. Remove Advertisements
