Misfire P0430 and P0420
Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Misfire P0430 and P0420 in Cadillac SRX / XT5 Forums; I have a 2006 SRX V8 and my codes are P0300, P0308, P0430 and P0420. The first two codes point ...
    st8w8 is offline Cadillac Owners Member
    Automobile(s): 2006 SRX 2000 Deville 1994 Seville STS
    May 2010
    29
    71
    I have a 2006 SRX V8 and my codes are P0300, P0308, P0430 and P0420. The first two codes point to a random misfire and a misfire on cylinder 8. I've changed all the spark plugs and the coil for cylinder 8 but the problem still persists. the car is idling really rough and sluggish upon accelerating and i can smell alot of exhaust. Was wondering if both cats are bad and would replacing them solve my problem. or is there something else wrong.
    glake89's Avatar
    glake89 is online now Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (gone), '07 GXP, 2010 li'l red wagon 3.6
    Aug 2010
    Interlochen,MI
    82
    2,947
    Re: Misfire P0430 and P0420
    Often overlooked on misfire codes is the injector which I suspect is your problem, especially since you have the 420 and 430 codes. The fact that you have both 04xx codes leads me to think some injectors on the other bank are also weak. That's where I'd look.
    Been fixin' cars for 74 years
    Professor Wizard's Avatar
    Professor Wizard is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 SRX-4 Sport / TriCoatWhite
    May 2009
    St. Louis, MO
    62
    1,096
    Have you ever had your Timing Chain replaced?
    May 2010
    29
    71
    No timing chains ever replaced. Just got it a month ago. How would I know if the injectors are bad.
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,947
    You can test the solenoids on the injectors yourself if you're handy and have a DMM. Flow testing or clogged is a bit more difficult but can be done if you're real handy. I suspect it's fairly high miles. You might try double dosing (cans/tankful) of a good cleaner such as Techron for 2 or 3 tanks.
    May 2010
    29
    71
    I've used techron twice in the past week. Going to change fuel filter and check the injectors later on today.
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,947
    If the ECT sensor reads between 50-90 degrees, look for 11-14 ohms across injector pins.
    May 2010
    29
    71
    Injectors are fine according to a local shop. They insist that the cats are in need of replacing
    I also unplugged each coil one at a time noting a difference in idle but no change when I did the #8. After the codes were cleared problem went away but an hour later rough idling and acting sluggish again
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,947
    The misfire may have damaged the cat, true. Check with customer service on this site for extended warranty on some cats, or your dealer. I seem to recall that there is some design problem in the N* that affects cyl.8. Maybe someone who knows will chime in. Interesting that erasing the code relieves the problem temporarily.
    May 2010
    29
    71
    Now getting misfire on 6 and 8. Wtf.
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,947
    Try disconnecting and re-connecting #2 connector on the ECM. There are 3 connectors, 1 &3 are 56 pin and #2 is 73 pin and black color. Injectors and coils both are in #2 and I suspect some pins are not making good contact.
    May 2010
    29
    71
    An update on my situation. Got the driver side catalytic converter replaced. Passenger side was fine. Also replaced all o2 sensors a total of 4. And still getting misfire on cylinder 6 and 8. The p0420 and p0430 codes are gone. Also misfire gets worse with the ac on.
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,947
    Is the MIL flashing or on steady? Are your only DTCs 300, 306 & 308?
  16. #14
    May 2010
    29
    71
    Only codes are 306 and 308. Mil stays on and only flashes upon hard acceleration.
  17. #15
    glake89's Avatar
    Aug 2010
    Interlochen,MI
    82
    2,947
    Here's my reading of your situation. The MIL flashes if the miss will likely cause converter damage; to me that means unburned fuel due to plug or coil being bad (not firing). Otherwise the CK sensor is detecting a slight discrepancy in crankshaft rotation. I suppose this could be caused by some unbalance condition but I lean toward not enough fuel in those 2 cylinders. If it were an electrical problem the would probably be separate DTCs for that. Sounds to me like physically pluggedor dirty injectors, or else something like coolant leaking in or out of them. Might be time for a compression and leak-down test. When your mechanic said the injectors were ok, did he remove them and do flow and spray pattern tests?
  18. Remove Advertisements
