Same Size Tires on AWD
Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Like Tree1Likes
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Same Size Tires on AWD in Cadillac SRX / XT5 Forums; I've just noticed that I've been running the same size tire all the way around on my AWD V6. What ...
    Dachristianman is offline Cadillac Owners Member
    Jun 2012
    46
    79
    I've just noticed that I've been running the same size tire all the way around on my AWD V6. What are the long-term implications of this? I've owned it for about 2 years and put about 20K on it.
    Tom
    08SRX's Avatar
    08SRX is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 SRX Sport Pkg
    Jun 2011
    1,050
    Re: Same Size Tires on AWD
    The answer to your question depends on the size of rim you have. Sport package comes with 20" rims which use the same tire sizes all around. If you have 18" rims, there are normally different sizes for front and back. Things to consider are: tire rotation, tire pressure monitoring system, effects on handling, stabilitrak and ABS. I have heard of others doing the same thing and don't think there is any ill effect, however, the vehicle was not designed for it.
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    I've had 265/35/22 on all 4 since I bought it put over 45k miles on them with even wear still had 75% tread left. 3.6 awd rotate and balance every 3k miles for me.
    nascarnation is offline Cadillac Owners Fanatic
    Automobile(s): 2004 SRX V6 AWD
    Aug 2008
    Indianapolis
    68
    494
    I've run 4 same size Blizzaks (17s) for 5 winters, now I'm running 4 same size Ecopias for summer on my 2004 awd.
    BEARBAIT1973 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 SRX V8 AWD
    Nov 2013
    New Lenox,IL.
    68
    154
    I also switched to 4 same size 18" tires after getting quotes of$1400+ for 2 size Michelins. Put a set of Hankooks in the rear size at half the price and handling and traction are great. Did this about 30k ago with no problems. The dealer told me I couldn't do it but after talking with tech dept. at Tire Rack they said there would be no problem. Handling is better and I now can rotate tires. A win-win switch!! 2004 V-8 AWD SRX
    Aug 2008
    Indianapolis
    68
    494
    Quote Originally Posted by BEARBAIT1973 View Post
    Let's hand them the "real men of genius" award.
    235/65-17 revs per mile = 719
    255/60-17 revs per mile = 719
    Jun 2012
    46
    79
    Thanks for all the replies. Not sure why Cadillac put different size tires on the front and back if they're the same diameter, but I'll stick with the same size.
    Tom
    Stillrollin is offline Cadillac Owners Fanatic
    Automobile(s): 2008 SRX AWD V-6
    Mar 2011
    N. Ridgeville, Ohio
    75
    177
    I've been running 255-50-20's at both ends on aftermarket rims since 2011. Put 35,ooo miles on them with no problems.
    Handling is good and stopping distance cut measurably .RPM's @ 65 mph dropped below 1900.
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    If stopping distance was cut measurably then please post how much it was cut by.
    Just so you guys know the front tires are as wide as the rear in the staggered size, you guys know that right?
    brianw is offline Cadillac Owners Member
    Automobile(s): 2004 SRX AWD V8 - 2014 F-150 SCREW
    Dec 2010
    38
    66
    what size are you running? 235/60/18 or 255/55/18? Does it make a difference?
    Sep 2007
    2,621
    Does not matter, most go to the bigger size.
    Dec 2010
    38
    66
    Quote Originally Posted by conedoctor View Post
    that's what I would like to do, but my fronts are in good shape.
    Sep 2007
    2,621
    I am not one to wait till things are "used up" to get what I want so I am of no help.
  16. #14
    BOOM_FIST is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac SRX
    May 2013
    47
    I went to 255/55/18 Toyo's on all 4 corners. The wide tires from the rear looks so much better IMO than the 235's, but I don't think it matters at all. Personal preference is what it comes down to.
  17. #15
    Nov 2013
    New Lenox,IL.
    68
    154
    255/55/18 I went with the larger size for better traction in snow. If you don't deal with snow I guess you could go with smaller size to save some money. Both have the same circumference so it shouldn't affect your speedo.
  18. Remove Advertisements
