How to disable F55 suspension on 2005 SRX - Page 2
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 52
Like Tree6Likes
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, How to disable F55 suspension on 2005 SRX in Cadillac SRX / XT5 Forums; That right, not common. But find a lot of 50W 6 ohm on Ebay for use on car to remove ...
  1. #16
    floods's Avatar
    floods is offline Cadillac Owners Member
    Automobile(s): CTS 2003 and Eldorado 1974
    Feb 2010
    90
    Re: How to disable F55 suspension on 2005 SRX
    But find a lot of 50W 6 ohm on Ebay for use on car to remove error when using led bulb.
  2. #17
    BOOM_FIST is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac SRX
    May 2013
    47
    Quote Originally Posted by floods View Post
    Just found the right 6 ohm 50 watt on Ebay.
    Will keep you informed when i receive them and if that work
    Thanks for help
    Good deal, good luck!
  3. #18
    floods's Avatar
    Feb 2010
    90
    Thanks
  5. #19
    May 2013
    47
    UPDATE!!!!!
    So, my wife calls me 2 days after I installed these and told me the error message, "Speed limited to 80", came back on and hasn't gone away. I called Suncore and talked to Sarah (Tech) and she informed me that they should have sent me a 3 ohm resistor instead of the 6 ohm. They're sending me out new 3 ohm resistors now.
    So sorry if this has inconvenienced you! BUY 3 OHM RESISTORS!
    Ludacrisvp likes this.
  6. #20
    floods's Avatar
    Feb 2010
    90
    Thanks for update, no problem, i will order again 3 ohm resistors.
    Thanks for help.
  7. #21
    floods's Avatar
    Feb 2010
    90
    Hi all,
    I install the 4 resistor on my SRX, i use 2.7 ohm 50W resistor, and it look to work perfectly.
    Thanks for help.
  8. #22
    nolasco1988 is offline Cadillac Owners Member
    Automobile(s): srx
    Apr 2014
    29
    1
    @floods were did you get the resistors? does anybody knows if this would work on my 2006 Cadillac rsx I just replace all 4 shocks to passive from magnetic active and now is showing speed limited to 80mph any advice would be great graciasssssss
  9. #23
    floods's Avatar
    Feb 2010
    90
    Hi,
    I order it in France at this link :
    http://www.electronique-diffusion.fr...ducts_id=28101
    But you can find it at any electronic store.
    I think that work for the 2006 too, it use the same system.
  10. #24
    Fabiantimmerman is offline Cadillac Owners Member
    Automobile(s): None
    Aug 2014
    None
    1
    Floods,
    I have a similar problem. Did it work?
    Did you change 1 shock, or more? How is the ride/handling?
    Fabian
    Netherlands
    Floods,
    Did it work? How is the handling of the srx?
    Did you change one or more shock absorbers?
    Fabian
  11. #25
    Tiger1106 is offline Cadillac Owners Fanatic
    Automobile(s): SRX'05 4.6L
    Jul 2014
    235
    I have info on several cars trying different resistors and different specs working for different years. The biggest problems being 2004 (2005 model years). So one may need to try different resistance for it to work. One sure thing that always works is resistors cut out of old MRC shocks (the rod from connector to bottom can be cut).
  12. #26
    REALTORBENJAMIN's Avatar
    REALTORBENJAMIN is offline Cadillac Owners Fanatic
    Dec 2012
    275
    Expensive but I wonder if these would work... http://www.ecklerscorvette.com/corve...2005-2012.html
    I did Strutmasters on the rears of my 05 STS and they work great. I tried asking if they would send me 2 extra resistors but they refused...
  13. #27
    floods's Avatar
    Feb 2010
    90
    Sorry for late reply.
    I change the 4 shock, and i put on the 4 wire a 50W 2,7 OHMS resistor, and that work perfect for me since i install it.
    Ride is perfect, just same as the non F55 suspension system, and that ok, feel good.
  14. #28
    Dec 2012
    275
    Sorry for late reply. I change the 4 shock, and i put on the 4 wire a 50W 2,7 OHMS resistor, and that work perfect for me since i install it. Ride is perfect, just same as the non F55 suspension system, and that ok, feel good.
    Did you use a specific type of solder?
  15. #29
    floods's Avatar
    Feb 2010
    90
    No, i use the most standard solder, noting special.
  16. #30
    Dec 2012
    275
    Quote Originally Posted by Tiger1106
    Explain... Is there something that can be salvaged from the existing shock that works like a resistor?
  17. Remove Advertisements
