"Stability System Engaged" message on dash. almost "cuts out" on the highway. 04 3.6L
Results 1 to 6 of 6
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, "Stability System Engaged" message on dash. almost "cuts out" on the highway. 04 3.6L in Cadillac SRX / XT5 Forums; Sorry to repost something thats probably already been answered, but I have been digging for a relevant answer to our ...
    nikijtbella is offline Cadillac Owners Member
    Automobile(s): 2004 3.6L V6 SRX
    Mar 2014
    1
    Sorry to repost something thats probably already been answered, but I have been digging for a relevant answer to our issue for a few hours to no avail. My boyfriend just called from work and said that hes currently driving on the highway and every once in a while the dash will read "stability system engaged" and the car almost seems to cut out for a second. ive read a ton of things about having issues with the ABS and such when it says that, but nothing about this. he had the traction control on but shut it off and must still be having the issue because when i called back with a possible fix he didnt say it stopped. could it be the seemingly notorious steering wheel positioning sensor that seems to be the culprit in other stability system issues? or something else? anyone else had this problem or know the cause?
    thanks so much.
    didnt realize my header got cut off. its an '04 3.6L V6 SRX
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,559
    Re: "Stability System Engaged" message on dash. almost "cuts out" on the highway. 04
    well to allow drivability he can press and hold the T/C button down for about 10 seconds and the car will turn off the Stability control and Traction control systems until you are able to determine the cause of the issue.
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,622
    I think you have it covered, wheel sensor or steering position sensor.
    johns12 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 SRX V8
    Nov 2010
    147
    Quote Originally Posted by conedoctor View Post
    Not necessarily, It could be the steering position sensor, yaw sensor under the passenger seat, wheel hub speed sensor ( in any of the 4 hubs) abs cable problem from wheel sensor, etc. It's best to have any stored codes read to determine what could be causing the problem.
    Sep 2007
    2,622
    Well I said two of the 3 you did and I cant remember anyone having a yaw sensor ever fail.
    If we want to split hairs it could be a pile of other stuff too but none worth mentioning at this point.
    glake89's Avatar
    glake89 is online now Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (gone), '07 GXP, 2010 li'l red wagon 3.6
    Aug 2010
    Interlochen,MI
    82
    2,948
    If you want to know what's wrong, get your DTCs read and report back, no more guessing.
    Been fixin' cars for 74 years
  9. Remove Advertisements
