Newbe please please help
Results 1 to 8 of 8
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Newbe please please help in Cadillac SRX / XT5 Forums; Hello to all . i have 05 Cadillac srx awd v8 i changed the rear shocks with the forums help ...
    preforming is offline Cadillac Owners Member
    Feb 2014
    56
    18
    Hello to all . i have 05 Cadillac srx awd v8 i changed the rear shocks with the forums help i changed the struts and axels,as well as carrier differential. now i can not get the upper control arm reattached after new axles.i try to jack under lower ball joint but it just jacks the whole car up.. any ideas ??
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6, 07 Solstice GXP
    Aug 2010
    Interlochen,MI
    81
    2,783
    Re: Newbe please please help
    From the SM, order of install-
    Click here for detailed picture of above image.
    Important: Loosely install all fasteners before tightening.
    Install the upper control arm to frame mounting bolts.
    Install the upper control arm to frame mounting nuts.
    Install the upper control arm to the knuckle.
    Notice: Refer to Fastener Notice in the Preface section.
    Install the upper control arm to knuckle retaining nut.
    Been fixin' cars for 74 years
    Feb 2014
    56
    18
    with everything loose it is still difficult to push the upper arm up. i changed the cv axels and struts at the same time. could i possibly have to much torque on the springs?
    i tried to put some pictures up could not get them to go through.
  5. #4
    Feb 2014
    56
    18
    should i take the strut off put the control arm in there and then try to get the strut up?
    the part of the strut that goe into the rotor is this the upper ball joint instead of control arm?
  6. #5
    maddoggyusa is offline Cadillac Owners Member
    Sep 2010
    40
    sounds like you may need to rent a spring compressor? it's like a clamp you use to compress spring on strut... allowing you to bolt everything together... when done reomve spring compressor.
  7. #6
    Feb 2014
    56
    18
    i think they may have sent me the wrong cv axels.. i.ll keep you posted on the matter..
  8. #7
    Feb 2014
    56
    18
    i have a strut compressor the struts and axel are new i dont know how to resize the pictures from my phone to put on here i think it is the cv axel .when i first did the struts i left old axels on. worked fine so i did the idiot thing and threw the old ones out. the new ones where same length and size slid right in. but i can not get the control arm for the rotor back into the strut..
  9. #8
    Feb 2014
    56
    18
    it's the axel. whent to junk yard went right in.
  10. Remove Advertisements
