Tip to change valve cover gaskets on 04 srx 4.6l v8? Issues w/leaking?
Results 1 to 2 of 2
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Tip to change valve cover gaskets on 04 srx 4.6l v8? Issues w/leaking? in Cadillac SRX / XT5 Forums; Does changing the Valve Cover Gasket on the Passenger Side of 4.6l V8 require lifting the motor. I've replaced twice. ...
    toddkellogg is offline Cadillac Owners Member
    Automobile(s): 2004 srx v8
    Jun 2012
    17
    Does changing the Valve Cover Gasket on the Passenger Side of 4.6l V8 require lifting the motor. I've replaced twice. Still leaks....dammit! Put sealant on the second time (against the gasket manuf. instructions). Its holding on the other side (I think).
    Took it to my local chevy dealer(yes, chevy, they are really good) and they said the Northstar valve covers are Notorious for Warping!!! Imgine my horror after hearing this. NO GASKET OR GLUE WILL COMPENSATE FOR A BENT VALVE COVER! Dammit again, the time and energy I put into replacing that gasket and I hear that!
    Had to loosen one bolt from UNDER THE CAR.
    Anyone else having this/these issues? OIL SMELL IS ANNOYING W/ AC ON AND WINDOWS UP.
    ANY TIPS? THE PASSENGER SIDE IS ESP. DIFFICULT TO REMOVE? HARNESS N FENDER BESIDE MOTOR.
    DO I JUST NEED TO BUY NEW VALVE COVERS? ARE THEY MADE? IN STOCK W/ GM? My car has 128k miles n I otherwise enjoy it.
    08SRX's Avatar
    08SRX is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 SRX Sport Pkg
    Jun 2011
    1,050
    Re: Tip to change valve cover gaskets on 04 srx 4.6l v8? Issues w/leaking?
    If your cover is warped, I would replace it. You will never be able to get a proper seal if the cover is warped.
