Guess what? Timing chains (and cylinder heads)
Results 1 to 8 of 8
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Guess what? Timing chains (and cylinder heads) in Cadillac SRX / XT5 Forums; Well the caddy got 2 codes for intake and exhaust timing, took the car to dealer and sure enough the ...
    It's hers is offline Cadillac Owners Member
    Automobile(s): 07 srx
    Nov 2013
    18
    Well the caddy got 2 codes for intake and exhaust timing, took the car to dealer and sure enough the chains are bad, they would let me know if under warranty. (67,000 miles). It's been a week so I called today and they said the chains are under warranty but the chains damaged the heads! So they have to see if the heads will be covered under warranty? Ummmmm question mark on that? Their faulty design of timing chains damaged the cylinder heads and we have to see if it under warranty even though the chains are? 2007 3.6 awd srx. Trying to convince her to sell it and get a 4 door wrangler, done with gm after this car. I'll post the answer I guess when gm calls back dealership.
    Sent from AutoGuide.com Free App
    SC2150's Avatar
    SC2150 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    61
    1,848
    Re: Guess what? Timing chains (and cylinder heads)
    We keep several sets of the cylinder heads here (good used with the valves cleaned) for $600 a set if they try to charge you.
    08SRX's Avatar
    08SRX is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 SRX Sport Pkg
    Jun 2011
    1,069
    I thought the 3.6L V6 was a non-interference engine, meaning that a broken timing chain would not damage the cylinders. Comments anyone?
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,622
    Broken wont but poorly timed could.
    Nov 2013
    18
    Well I'm being taken for $1000.00 by the thieves at gm, I guess warranty doesn't mean much any more these days!
    Nov 2013
    18
    From what I'm getting is the chain itself rubbed against the casting
    Sep 2007
    2,622
    Should it be warranty?
    Like is it part of the timing chain extended coverage?
    Nov 2013
    18
    Not sure if it would be, just a little upsetting that the part that's under extended warranty, damaged another part that's not. That's the fine line I guess.
  11. Remove Advertisements
