Hi beams come on with turn signal
Results 1 to 3 of 3
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Hi beams come on with turn signal in Cadillac SRX / XT5 Forums; Have had this problem about a year so finally bought new multifunction switch at Rock Auto. Put it in today ...
    Jim_V is offline Cadillac Owners Fanatic
    Automobile(s): SRX V8 RWD 2004
    Feb 2005
    Pasadena Maryland
    153
    Have had this problem about a year so finally bought new multifunction switch at Rock Auto. Put it in today in less than an hour. Not too hard but lower screw required a torx bit and 5/16 open end wrench to prevent too much disassembly. Works great. Only issue as someone else mentioned on another thread was the upper and lower steering column covers have a blind attachment that broke but went back together fine and looks good.
    Janisrick is offline Cadillac Owners Member
    Automobile(s): 2006 SRX V-8 AWD
    Sep 2013
    69
    9
    Re: Hi beams come on with turn signal
    You didn't have to remove the steering wheel did you? Also, what did you need the 5/16 wrench for? I thought just torx head screws hold this thing together.
    Feb 2005
    Pasadena Maryland
    153
    Since I didn't remove steering wheel I used a torx bit and turned it with the wrench.
