replacing front struts
Results 1 to 8 of 8
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, replacing front struts in Cadillac SRX / XT5 Forums; I'm getting ready to do this job for my friend. But am curious about the front mount/ a arm assembly. ...
    big greg is offline Cadillac Owners Fanatic
    Automobile(s): 2006 dts
    Oct 2012
    32
    255
    I'm getting ready to do this job for my friend. But am curious about the front mount/ a arm assembly. Do you simply unbolt just the strut from top or does the while a arm come with? I'm just asking if someone else had done this job. Thanks
    johns12 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 SRX V8
    Nov 2010
    147
    Re: replacing front struts
    There is a shock mount yoke attached to the lower control arm. That has to be removed. Then the upper control arm has to be removed. Remove the three bolts up top in the engine compartment and the strut with upper control arm can be removed as one unit.
    CaddyObsessed is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac SRX V6 RWD
    Jan 2009
    3 Hours from Santa!
    25
    I just did this job 3 weeks ago. The first side (passenger) I removed the whole strut assembly and changed the shock out on the bench. The drivers side I got smarter and left the strut assembly on, just undid the lower mount and the upper nut with a long socket. The shock just drops out. I had to use spring compressors on both sides. Passenger side took 4 hours, drivers side was an hour and a half. Hope this helps!
    Oct 2012
    32
    255
    Sweet. That's what I was thinking of doing. Now if only The Shocks Would Get Here. Found ac Delco front for 75$ on ebay. Rears for 230. But that was 12 days ago and there still not here. Stupid ups. And snow
    Oct 2012
    32
    255
    Just completed the job and I had to remove the a arm assembly. Because the nut just spun on the top. Wasn't too bad. Changed out front and rears in 4 hours.
    david1 is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Nov 2007
    Malvern, Pa
    46
    187
    Did you mark the upper spring bushing so it went back the way it came out ? I didn't on the first side but did on the other ie end of spring faces wheel on one side and the engine on the other. I don't think it makes a difference otherwise GM would index it, right ?
    top tiger is offline Cadillac Owners Member
    Feb 2007
    10
    Is the spring preload released when you remove the top nut?
    Nov 2010
    147
    You have to compress the spring before undoing the nut.
  11. Remove Advertisements
