Questions About Buying a 04 to 09 SRX
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By conedoctor
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Questions About Buying a 04 to 09 SRX in Cadillac SRX / XT5 Forums; We are replacing our beater 96 Jeep Grand Cherokee with 180K on the clock because repairs for that car over ...
    roadbike56 is offline Cadillac Owners Member
    Automobile(s): None
    Nov 2012
    13
    We are replacing our beater 96 Jeep Grand Cherokee with 180K on the clock because repairs for that car over last year equal car payments. Based on price, the SRX looks like an attractive possibility. However, I have two concerns about the 04 to 09 model. The first is the reports of high oil consumption with the V-6. Is it possible to detect if the car has the high oil consumption problem before buying? The second is the MRC system. I've read that many owners have to replace the shocks within this system and they are quite expensive. How can I tell if the car I'm looking at needs the MRC shocks replaced.
    I'm interested in the SRX model, but I'm not interested in trading for a car with worse problems than the current 96 Jeep.
    Any help here is appreciated.
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Simple solution.
    Avoid the V6 and don't buy an srx with electrical connectors on the top of the struts.
    Easy
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,482
    Agreed.
    Also know that the 07-09 have a much nicer inside than than the 04-06 (damn near exact clone of the CTS).
    07+ also gets a 6spd trans so slightly better mpg is possible.
  5. #4
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Quote Originally Posted by Ludacrisvp
    Agreed.
    V8 in 07 got 6 speed. Not sure about v6.
  6. #5
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,482
    Quote Originally Posted by 1BadCadSTS View Post
    True.
    I'd wonder if the V6 ever did get it since it wasn't updated to the DI V6 in 2008 like STS was.
  7. #6
    silversport's Avatar
    silversport is online now Cadillac Owners Enthusiast
    Automobile(s): **2014 CTS4 Sport Wagon-Luxury**Gone-2000 Escalade**2008 SRX
    Nov 2007
    ChicagoLand, USA
    769
    Re: Questions About Buying a 04 to 09 SRX
    nope...the V6 has a 5 speed automatic with manual shift capabilities...
    Bill
  8. #7
    Automobile(s): None
    Nov 2012
    13
    Thanks for the replies. I know the V-8 has a better reputation with regard to the oil burning problem, but the prices of the V-8 SRX are substantially higher than the 6 making the SRX less competitive price wise. I appreciate the comment about the nicer interior, but I'm buying an SUV that will take some abuse so interior is not a high priority. I'll keep that information in mind if an 07 is priced close to a 05/06. I think as far as the MRC sysem goes, I'll follow the advice and check under the hood.
    What I really need to know, is there a way to test the V-6 to detect if it's an oil burner? Are there any tell-tale signs? Do these engines lose compression?
    Any help here is much appreciated.
    Many thanks.
  9. #8
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Quote Originally Posted by roadbike56
    Many thanks.
    Sure the price is cheaper. Until you tack on timing chain and valve guide replacement to the bill.
    Otherwise if they let you have it for 1000-2000 mile test drive you'll be able to figure it out...
  10. #9
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,482
    It's much worse than just "oil burning" timing chains are known to stretch and break. And iirc this is an interference motor so should they break at speed your motor is basically toasted.
    Sent from AutoGuide.com App
  11. #10
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    Not too mention if it has the panoramic sunroof more money for constant repairs. And avoid awd also known failure in the transfer case chains.
  12. #11
    Automobile(s): None
    Nov 2012
    13
    OK, so to summarize, stay away from a 6 cylinder engine, avoid AWD, avoid a car with MRC, and finally avoid a car with panoramic sunroof.
    Wow, that really narrows the field. Thanks to all the responders for filling me in on the pitfalls. Glad I asked.
  13. #12
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Awd is not a major problem. The tcase chain can have an issue but its not nearly as common as the other issues. The sunroof becomes a problem because how massive it is. Without maintenance (applying lube to the tracks and cleaning debris) it stresses the motor and tracks. Awd and a sunroof wouldn't steer me away.
  14. #13
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,482
    In the several years of ownership and over 150k miles combined during ownership (around 200k miles total between them) the 04 & 06 AWD N* SRX's that my parents drive both have the ultraview moonroof too; neither have had any issues with the transfer case nor the roof.
  15. #14
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    Quote Originally Posted by repnatl View Post
    This is totally false.
    If you avoid the Ultra-view, AWD and all the other things then why not just say avoid the SRX like you want to. Providing false inaccurate information to a person is not helpful.
    Ludacrisvp likes this.
  16. Remove Advertisements
