08 Blower Fan
Results 1 to 11 of 11
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, 08 Blower Fan in Cadillac SRX / XT5 Forums; My 08 blower fan is not working, the lights on the dials turn on, but no fan motor, and as ...
    fdnylt is offline Cadillac Owners Member
    Automobile(s): 02 SLS, 08 SRX
    Feb 2011
    55
    41
    08 Blower Fan
    My 08 blower fan is not working, the lights on the dials turn on, but no fan motor, and as you can imagine its cold outside. Any advice would be greatly appreciated, location of the fuse(s) to start, and maybe how they are marked. Thanks!
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Owners manual blower motor fuse.
    Feb 2011
    55
    41
    Re: 08 Blower Fan
    Ok Thanks, checked that fuse and it is good. Anything else I can try?
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    The tapping the blower motor itself underneath the passenger side dash there is a panel to.remove. tap it and or fool with the wiring and see if it comes on. If it does the. One of those is the issue. Otherwise apply direct battery power with some wire to the positive side of the blower plug. If it comes on it is a climate panel or wiring/relay issue.
    Feb 2011
    55
    41
    Re: 08 Blower Fan
    Ok, I have power to the motor. So I'm thinking the blower motor is bad, Advanced Auto parts has them in stock, has anyone used them and are they a good fit? Thanks Again for the advice.
    Oct 2012
    975
    Should fit right haven't had issues with those.
    Feb 2011
    55
    41
    Re: 08 Blower Fan
    As a follow-up, Thanks Again for all the advice. I pulled the blower motor out, and then directly connected it to the battery before I picked a replacement. And to my surprise, it worked! So I checked the wire connector into the blower once again, and it still was good, so I plugged the blower back in and it works. So my question is, I'm usually not that lucky, so what may have caused the temporary failure?
    silversport's Avatar
    silversport is offline Cadillac Owners Enthusiast
    Automobile(s): **2014 CTS4 Sport Wagon-Luxury**Gone-2000 Escalade**2008 SRX
    Nov 2007
    ChicagoLand, USA
    799
    Re: 08 Blower Fan
    dirty connections maybe...you unplugging and plugging back in may have been all it needed to make a good connection again...good luck...glad it worked out for you...
    Bill
    Oct 2012
    975
    I've seen those connections go bad easy replacement
    Nov 2007
    ChicagoLand, USA
    799
    Re: 08 Blower Fan
    good advice from repnati too if your problem reemerges...
    Bill
    Oct 2012
    975
    What I do it cut the bad plug off and replace the end with some new spade connectors and plug them in individually and no I've never seen a short or fire caused by that.
  14. Remove Advertisements
