2004 driver door wont' shut in cold weather
Results 1 to 5 of 5
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, 2004 driver door wont' shut in cold weather in Cadillac SRX / XT5 Forums; it's the wife's car so I need to fix quickly. Is it a lube problem or do I need to ...
    maddoggyusa is offline Cadillac Owners Member
    Sep 2010
    40
    it's the wife's car so I need to fix quickly. Is it a lube problem or do I need to replace the lock and/or latch? Is there a TSB? I keep getting mixed info.
    When it's cold around 30F, the driver door won't stay shut. If it warms up (driving or put in garage), it starts working again. The striker is in the correct position, it just won't latch and stay shut. As it warms up it initially starts to barely latch and then will slowly start to latch properly. Definitely cold related.
    08SRX's Avatar
    08SRX is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 SRX Sport Pkg
    Jun 2011
    1,037
    Re: 2004 driver door wont' shut in cold weather
    Sounds like it just needs lubrication. I would get it warm (if you can) and apply lots of lubricant and work it into the mechanism thoroughly by moving it back and forth.
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2010 li'l red wagon 3.6
    Aug 2010
    Interlochen,MI
    82
    2,873
    Or, if it has a greasy lube on it now that is affected by temperature, you may want to try a cleaner/solvent first to remove the old before adding new.
    Been fixin' cars for 74 years
    Sep 2010
    40
    OK, I'll do that and see how it goes. Thanks!
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    Thaw it and spray some WD into it to displace the moisture. It is freezing and binding.
    Some cars had a recall for something similar but I think they were newer models.
    Be sure someone runs your VIN to identify any possible safety recalls, any dealer should do it by phone.
  8. Remove Advertisements
