Washer fluid leak and running light bulb
Results 1 to 2 of 2
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Washer fluid leak and running light bulb in Cadillac SRX / XT5 Forums; Washer fluid is leaking into my rear hatch when I try to wash the rear window what is the best ...
    Kentuckeyjelly is offline Cadillac Owners Member
    Automobile(s): 2009 srx
    Dec 2012
    16
    Washer fluid is leaking into my rear hatch when I try to wash the rear window what is the best way to take the trim panel off? Also my right front turn signal -running light is out how do u get to the bulb thanks
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (on the way out), '07 GXP, 2012 li'l red wagon 3.6 AWD
    Aug 2010
    Interlochen,MI
    82
    2,833
    Re: Washer fluid leak and running light bulb
    Panel, 1 screw in interior hand slot, then panel pulls off (clips). Pull off enough to undo elec. connector.
    Bulb, remove tire and fender liner then you can get to 2 bolts that hold assembly to fascia.
    Been fixin' cars for 74 years
