Shell Gasoline and Intake Valve Deposits
Results 1 to 7 of 7
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, Shell Gasoline and Intake Valve Deposits in Cadillac SRX / XT5 Forums; It's true. It's clean. If your valves have deposits, you're using the wrong gasoline. Period. This engine has no silly ...
    ktr-sb is offline Cadillac Owners Fanatic
    Automobile(s): 06 SRX 3.6L 2WD
    Mar 2004
    427
    It's true. It's clean. If your valves have deposits, you're using the wrong gasoline. Period. This engine has no silly "catch can," has a high oil consumption rate, has original valve stem seals, has seen factory OCIs using some dino (but mostly synthetic) oil, and has a history of light sludging.
    Anyone who tells you otherwise doesn't know what they are talking about.
    SC2150's Avatar
    SC2150 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    61
    1,848
    Re: Shell Gasoline and Intake Valve Deposits
    On a Non-DI you are correct, we have heads in here with 140,000 miles on them and not a spec of deposits anywhere the fuel spray makes contact. But the oil causes detonation, less power, and carbon build up on the pistons and combustion chamber on port injection engines so the benefits are many for all engines.
    But the DI engines are totally different as the fuel never touches the intake valves
    Here is a port injection engine showing how the fuel is constantly drenching the intake valves so the detergents not only keep them clean, they also keep deposits from forming in the port where they touch as shown here:
    Port injection:
    And a DI:
    There is not a DI engine made that the fuel touches the intake valves in any amount that the detergents can have any effect.
    I tear these down non stop and we also do on the car manual valve cleaning.
    Here is a before and after of the manual cleaning:
    JayTF1 is offline Cadillac Owners Fanatic
    Automobile(s): NONE
    May 2012
    37
    144
    good stuff guys, thanks. SC2150: good tips = Direct injection vs Port injection
    I swear by top tier gasoline, and shop at Shell religiously for my Northstar. Everyone tells me I'm crazy for turning my nose up at cheaper gas, but I feel it makes a difference in the long run.
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    61
    1,848
    It is critical on any non DI as far as valve deposits. Now piston ringlands will still build up oil burn residue and cause the rings to not move freely compounding the oil consumption issues, but there is no disputing the effect on intake valves.
    Here is an example of a DI engines run with top tier fuels:
    That is where stopping the oil ingestion is critical.
    Sheepish is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Cadillac SRX V8 AWD
    Aug 2012
    Kalamazoo, MI
    48
    335
    which injection method do the northstars have?
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    61
    1,848
    Port injection. Use a good top tier detergent fuel and your valves will always look like new.
    Mar 2004
    427
    I am not going to start another flame war, and get ready for another core dump of information, but GM says their direct injection engines do spray gasoline on the intake valve precisely to reduce these kinds of deposits that other engine manufacturers see.
  10. Remove Advertisements
