2005 srx heated seats
Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Like Tree1Likes
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, 2005 srx heated seats in Cadillac SRX / XT5 Forums; Good morning all. Here goes my second post. I have looked at all my rpo codes and nowhere is it ...
    cuffs9999 is offline Cadillac Owners Member
    Automobile(s): 2005 srx
    Feb 2013
    boston ma
    18
    Good morning all. Here goes my second post. I have looked at all my rpo codes and nowhere is it listed that I have heated leather seats as an option. There is no button to push to activate the heated seats. . However on very cold mornings when I use the auto start and come out to my car the seats have been very warm and the heated seat icon on the climate display have been lit up indicating that I have heated seats. My car is an 05 built in May 04. Probably at the beginning of the model year swap. I just bought a climate control unit that has the heated seat button on it. Can anyone help me on what's going on. And if I can plug and play with the new climate unit. Thanks.
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Aftermarket auto start I presume?
    Feb 2013
    boston ma
    18
    I would assume so. I didn't even realize that I had auto start until I was fooling around with the fob one day. I believe it's an ultra start. Do u think they installed heated seats at the same time? How would I check that
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    I think when they wired it to the hvac that upon power up it just lights up the icon. What happens when you stick the key in and "start" it after the remote start.
    Feb 2013
    boston ma
    18
    It has only come on two or three times. Only when it has been exceptionally cold. And only when I remote start. And the seats get really warm. When I get in and put the key in the heated seat icons stay lit and the seats stay warm. I've looked under both seats and nothing looks after market. It all appears to be factory.
    bendebusk's Avatar
    bendebusk is offline Cadillac Owners Fanatic
    Automobile(s): 2005 SRX
    Oct 2013
    NW Italy
    148
    Re: 2005 srx heated seats
    Interesting! If it really does have heated seats, I'm curious if they stay on all the time and what will happen in the summer?
    Feb 2013
    boston ma
    18
    There is no if-these things get really warm. And they go off. Either on their own or when I change the settings in the climate control after I get in the car. I just started it back up after being home for an hr or so. They did not come back on.
    glake89's Avatar
    glake89 is online now Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (gone), '07 GXP, 2010 li'l red wagon 3.6
    Aug 2010
    Interlochen,MI
    82
    2,942
    Per the SM, replacement of the HVAC control module should be plug n play, no programing needed. Whether wiring and heated seat module are in place is unknown.
    Been fixin' cars for 74 years
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    All hvacs are set up for heated seats via the screen but the controls is another thing. Ill bet its not really working your just seeing a ghost icon light up due to confusion over the databuss due to the remote start being spliced into your hvac.
    Feb 2013
    boston ma
    18
    Not sure what you mean by it's not really working. The seats are very warm. Unmistakably warm. And unmistakably working.
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Nothing in these cars is prewired. They didn't install heated seats and then were like well the car wasn't optioned for it and not install a headed seat hvac control. Blowing hot air from the vents upon remote start on leather will heat it up pretty fast. Even if someone added aftermarket ones there's no way it would cause the hvac to light up with them "on".
    bendebusk's Avatar
    Oct 2013
    NW Italy
    148
    Do the heated seat icons light up if you remote start without the heat on? If you start the car without the heater on, you could definitely see how hot the seats get on their own. My SRX has the heated seats option and there is both a high and low setting. But, as far as I know, they don't go off unless I manually turn them off or turn the car off.
    Feb 2013
    boston ma
    18
    Onebadcad I understand what ur saying. But I've been driving for 25 yrs. I can kinda tell when a seat is heated or just warm from being blown on. This is direct under your bum heat. I have tossed around the aftermarket seat thing. Nsince I bought the car used I will assume they had them out in. But why does the light on the climate control panel light up? Is it possible that the panel itself is actually a replacement and they put a non climate display on?
  16. #14
    holstbnet's Avatar
    holstbnet is offline Cadillac Owners Member
    Feb 2005
    Illinois
    38
    31
    Cuffs9999 - now THAT is pretty interesting. I think there's some sort of build anomaly with your SRX. Do you have a power passenger seat? I think the SRX seat options are that the non-heated seats are power drivers only, manual passenger. If you have heated seats then both are power as well. Just curious. What would be interesting is to get a SRX or CTS HVAC control head with the heated seat buttons and swap yours out, see what happens. I -think- that the SRX is pre-wired for heated seats regardless. I'm looking into this too, because I want to put heated seats in my '09 SRX (which is probably going to be a PITA.. they moved the heated seat buttons to the doors in 07-09)
  17. #15
    Feb 2013
    boston ma
    18
    Great to hear a response along the same lines that I was thinking. Yes I have power driver and passenger seats. I just received a climate control unit with heated seat buttons. I will be doing a swap out this week. I will keep u posted.
  18. Remove Advertisements
