Results 1 to 11 of 11
Thread: Winter Tire Pressure (psi)?
    pennypup is offline Cadillac Owners Member
    Automobile(s): '07 V8 SRX4 w/ Sport Package
    Jan 2012
    Quebec
    32
    25
    Hello All, it's me with yet another question for you.
    I am wondering what psi to set my winter tires at. I have a 2007 srx 4 with the 20" wheel option.
    For the winter I bought 17" rims and 235/65/17 Bridgestone Blizzaks. On the sidewall of the tire, it doesn't give the psi for them to be set at, just the max and refers to the manual or placard on the car for the pressure.
    However, the manual gives no info and the placard on the car gives the psi for the 20" tires only. (30 psi front, 32 psi rear)
    I'm wondering if the winter tires should be set at the same psi at my summer tires which sit on rims 3" bigger and low profile tires), or should I have a different psi for them?
    Last year I had them installed at a garage and they filled the tires; I guess I should have checked what psi they filled them to at the time, but I didn't. I installed them myself today, but now the SRX is sitting in the driveway, unused, as I suddenly realized I have no clue what psi they should be at LOL.
    At least this year, I realized I can set the tire pressure monitors myself and have done so. I drove around all last year with the tire pressure warning light on LOL!
    Thanks so much for your help. I really appreciate it!
    Stillrollin is offline Cadillac Owners Fanatic
    Automobile(s): 2008 SRX AWD V-6
    Mar 2011
    N. Ridgeville, Ohio
    75
    177
    Re: Winter Tire Pressure (psi)?
    My '08 SRX came with 17" wheels and the placard indicates 31psig all around.
    Nov 2013
    3
    It can be calculated with one of my spreadsheets, in wich I use the same formula that the European tyre-makers used for decades and the American TRA swiched over to in 2006. Later spreadsheets ( latest is my motorhome-calculator wich can be used for this too with some car so only by me) work with an even better one I made and is a combination of the official used and one I found described by an American IR J.C.Daws, and leads to saver pressures for the tires.
    So if you give the details from car and tires, I can calculate a save lowest pressure to use.
    I expect the 17" to need a lower pressure because the sidewall is higher, the given maximum load will be higher, or it is a P- tire and your 20"are XL/Extraload/reinforced , wich need higher pressure for the maximum load to carry. The 20" most likely are XL// , its often because of the low hight width division called Aspect Ratio, to give it the same diameter as the 17".
    From car
    GVWR ( gross vehicle weight rating) , GAWR's ( Gross axle weight ratings), If you have them real weight axle , or better even seperate wheel-weights in de condition you ride it.
    Maximum speed of car or speed you sertainly wont go over. Or empty weight and the way you load it ( persons and load) to estimate the axle loads.
    If it is done the camber angle of mostly only the rear wheels ( tires like this on the axle/-\).
    From tires the exact sises , Loadindex or maximum load, kind of tire and given maxload or maximum pressure. If the tires are off road kind with large profile blocks that cover the sidewall a part, yudge that and write it down too, those have lower maximum save load then is written on them.
    I answered without logging in or registering , only used the human verification, so wont get a message of new posts , but will follow this topic by making a favourit of it .
  5. #4
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    I set mine at 32F-34R, I would set them to 32 front/rear and call it a day.
  6. #5
    08SRX's Avatar
    08SRX is offline Cadillac Owners Connoisseur
    Automobile(s): 2008 SRX Sport Pkg
    Jun 2011
    1,050
    I know some people over-pressurize tires to save fuel, but this will wear out tires faster and can also cause potentially hazardous conditions. There are also some people who under-inflate to maximize traction in the winter. Bottom-line is: Tires should be pumped to the recommended pressure which is the same pressure level whether it is summer or winter.
  7. #6
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    All mine set at 40
  8. #7
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Quote Originally Posted by 08SRX
    Right, but the recommended pressure is wrong if you change tire size.
  9. #8
    Jan 2012
    Quebec
    32
    25
    Wow, that's a mouth full jadatis. I think you made my brain melt LOL
    Summer Tire Info: Goodyear Eagle RS-A 255/50/20 SL (44psi max)
    Winter Tire Info: Bridgestone Blizzak DMV-1 235/65/17 XL (50psi max)
    Car Specs: V8 AWD
    GVWR 7200lbs
    GAWR 4000lbs
    Max occupancy family of 5 (3 small children) plus big dog no more than 500lbs.
    Highest speed 130km/h (80-ish m/h)
    No camber of the wheels that I know of.
    I pumped the tires up to the recommended setting as per the placard for now, as I had to get around LOL
  10. #9
    Sep 2007
    2,621
    Quote Originally Posted by repnatl View Post
    All mine set at 40
    I can't see the trade offs being worth the saving in fuel.
    Back when I was a boy and I had my first AutoX car I ran 55-60 PSI in the tires so they would not roll over, the drive home was bumpy lets say lol man I could go through A520's
  11. #10
    Professor Wizard's Avatar
    Professor Wizard is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 SRX-4 Sport / TriCoatWhite
    May 2009
    St. Louis, MO
    62
    1,096
    I run 34 on all corners of mine.
  12. #11
    Jan 2012
    Quebec
    32
    25
    I ended up calling Cadillac Canada, and the woman I spoke with had no idea either and suggested I call the tire manufacturer. So I said f-it and set them all to 33psi LOL
  • You may not post replies
