Results 1 to 8 of 8
Thread: Just finished rear MRC shock installation now " Service Suspension System"
    Dakaty is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Apr 2007
    27
    I installed the rear MRC shocks yesterday on my 2006 SRX and now this morning I'm getting the "Service Suspension System" warning message. I also changed the rear brake pads while I was at it.
    Shucks. I was so proud of myself doing that install with no left over parts or screws, and now this!!! Is there a way to pinpoint the problem that is causing this message?
    Thanks
    Bummed Bill
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Make sure you seated the plug properly. There's a narrow pin in the middle and if you smash it down your fubar.
    You can pinpoint the message with a TECH II or high end Snap On scanner.
    glake89's Avatar
    glake89 is online now Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (gone), '07 GXP, 2010 li'l red wagon 3.6
    Aug 2010
    Interlochen,MI
    82
    2,921
    Re: Just finished rear MRC shock installation now " Service Suspension System"
    When you have no parts left over, you know you did something wrong. Double check all connections.
    Been fixin' cars for 74 years
  5. #4
    Apr 2007
    27
    Quote Originally Posted by 1BadCadSTS View Post
    I asssume that you are talking about the plugs on the top f the shocks that are behind all of the interior trim panels that I have painstakingly re installed?
  6. #5
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Yup those be the ones.
  7. #6
    Apr 2007
    27
    Well I just got done taking loose both sides of the interior panels to check for a loose connection and.... I had left the electrical connection off of the driver side shock.
    So pin a big ole FAIL button on me.
    After I plugged in the connection, tada, the error message went away. (Surprising isn't it?)
    I don't know whether to feel happy that I found and fixed it or feel sad for being such an incompetent dummy in the first place.
  8. #7
    warreneaux is offline Cadillac Owners Fanatic
    Automobile(s): 2006 SRX V8 Black/Black
    Sep 2010
    Houston, Tx
    78
    136
    Don't beat yourself up, at least you did the job and then found the mistake.
    Good job.
    Earl
  9. #8
    Professor Wizard's Avatar
    Professor Wizard is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 SRX-4 Sport / TriCoatWhite
    May 2009
    St. Louis, MO
    62
    1,096
    Glad you were able to fix the error.
    It is embarrassing when a DYI does such things... but shameful, when an experienced shop mechanic does the same thing.
  • You may not post replies
