Results 1 to 4 of 4
Thread: Mushy brakes
    BEARBAIT1973 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 SRX V8 AWD
    Nov 2013
    New Lenox,IL.
    68
    154
    Mushy brakes
    Just put all new calipers,rotors, and pads on 2004 srx. Bled brakes 3 times but pedal is still lower and mushy compared to before I did this. Any suggestions. There are other posts mentioning ABS pump.What does this involve?? Thanks
    Professor Wizard's Avatar
    Professor Wizard is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 SRX-4 Sport / TriCoatWhite
    May 2009
    St. Louis, MO
    62
    1,096
    Re: Mushy brakes
    Bump!
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6 (gone), '07 GXP, 2010 li'l red wagon 3.6
    Aug 2010
    Interlochen,MI
    82
    2,923
    Re: Mushy brakes
    From the SM-
    "The ABS Automated Bleed Procedure uses a scan tool to cycle the system solenoid valves and run the pump in order to purge any air from the secondary circuits. These circuits are normally closed off, and are only opened during system initialization at vehicle start up and during ABS operation. The automated bleed procedure opens these secondary circuits and allows any air trapped in these circuits to flow out toward the brake corners."
    That will fix your problem, maybe 2Hr. at dealer. Why not call one?
    Been fixin' cars for 74 years
  5. #4
    Nov 2013
    New Lenox,IL.
    68
    154
    Re: Mushy brakes
    Thanks for the info. Will definitely get it done.
  • You may not post replies
