2007 Tire Pressure Monitor problems
Results 1 to 12 of 12
Cadillac SRX First Generation Forum - 2004 - 2009 Discussion, 2007 Tire Pressure Monitor problems in Cadillac SRX / XT5 Forums; A few weeks ago, I got a "check right rear tire pressure" message on my dash. It showed a reading ...
    Terry Lange is offline Cadillac Owners Member
    Automobile(s): 2007 SRX
    Oct 2005
    Mesa, AZ
    42
    A few weeks ago, I got a "check right rear tire pressure" message on my dash. It showed a reading of 26 psi, which is the trigger to initiate the message. However, a check with an accurate tire guage showed a reading of 30 psi. I increased the pressure to 40 psi, but I still get the message and the reading of 26 psi. Yet, when I drive on the freeway and the psi increases on its own, the message disappears, and the reading shows 27 or 28 psi.
    I don't understand why the TPM is recognizing a 1 lb. psi increase from freeway driving, but won't recognize a 14 psi increase from an air hose.
    I stopped by a Big O tire store, and they wanted $30.00 to "scan" all 4 tpm's, but also admitted that they didn't figure that would solve the problem. I suspect the rr tpm is defective, and replacing it would solve the problem. I have an air compressor at home, so don't have a need to pay a tire shop to mess around with (and charge me for) air pressure adjustments.
    Any suggestions on what might be going on here? Thanks in advance for any advice.
    repnatl is offline Cadillac Owners Enthusiast
    Oct 2012
    975
    I've been having this same issue with my rr one dropping to 0 psi at random. Of course never happens while at the shop lol.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    28
    26,325
    The battery is probably dying. They're 6 years old.
  5. #4
    08SRX's Avatar
    08SRX is offline Cadillac Owners Enthusiast
    Automobile(s): 2008 SRX Sport Pkg
    Jun 2011
    992
    Re: 2007 Tire Pressure Monitor problems
    Please check the pressure in all your tires. You may find that tires were rotated, but TPMS was not updated. Therefore, wheels may be in different locations from what the monitor thinks. There is a danger that you are over-inflating the wrong tire thinking it is the one with low pressure.
    Typical tire rotation is as follows, which may help you find the true low pressure tire:
    LF to LR
    RF to RR
    LR to RF
    RR to LF
    Hope that helps!
  6. #5
    Oct 2005
    Mesa, AZ
    42
    08SRX, thanks for the info. You were right on. I went to a Discount Tire store today, and they took a "reading" on all 4 tires, and determined that the left rear, not the right rear, had a dead sensor. I rotated the tires in my driveway a year ago, and according to the tire store, my right rear tire still thinks it is on the left rear! I tried to reprogram the system at that time from the instructions in the owner's manual, but could not get the horn chirp from the first tire, so it was all down hill from there.
    What was interesting today, is that Discount Tire took a tread measurement of all my tires, and determined that it would be "unsafe" to dismount one tire, install a new TPM, and remount the tire for "safety and liability reasons". Some 18 year old kid is going to tell me that I need $850.00 worth of new tires before they will help me, when after almost half a century of driving cars, I have always made the decisions of when the tires needed to be replaced (and haven't guessed wrong yet.) I only drive about 5K a year in this car, and know that the existing tires are good for at least one more year. Not a money issue at all, I just don't like throwing away something that is still serviceable. Looks like I will be driving around for a year with that orange light glowing in the dash.
  7. #6
    Oct 2012
    975
    On some vehicle not sure about ours but would lose cruise control and or eventually traction control with the tpms light on.
  8. #7
    Professor Wizard's Avatar
    Professor Wizard is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 SRX-4 Sport / TriCoatWhite
    May 2009
    St. Louis, MO
    61
    1,096
    I think my next set of tires will all be the same size, so I can start "rotating" them.
    Every time I get my tires replace, they miss assign the TPMS on the wrong tires.. Then the system tells me my right rear is low, but really it was the left front, for example.
    I've learned to check that before leaving,,, I let a little air out of a tire in the parking lot, then look to see when one drops in the system.
  9. #8
    silversport's Avatar
    silversport is offline Cadillac Owners Enthusiast
    Automobile(s): **2014 CTS4 Sport Wagon-Luxury**Gone-2000 Escalade**2008 SRX
    Nov 2007
    ChicagoLand, USA
    768
    Quote Originally Posted by Terry Lange View Post
    good luck elsewhere but welcome to the world of nannies brought on by lawsuits for spilled coffee being hot...imagine buying coffee and after spilling it finding it was hot...who can we blame...
    Bill
  10. #9
    Linkinyeah is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac SRX ALL WD V8
    Aug 2013
    31
    Dumb question. I have a 2005 V8 AWD. The front tires are different sizes than the back, so I can never really rotate the tires from front to back. Is this correct?
  11. #10
    Ranger007 is offline Cadillac Owners Member
    Automobile(s): 2008 SRX 3.6
    Apr 2010
    Oklahoma City
    83
    repnatl said
    "On some vehicle not sure about ours but would lose cruise control and or eventually traction control with the tpms light on."
    Never heard that, but probably true. Above referenced "world of nannies". I always thought the light staying on was annoying enough.
    Linkinyeah, yes they came with different sizes from front to back. When I replaced them, I put the same size all around. Don't remember the size I went with, but the tire shop had no problem with my choice.
    Bill
  12. #11
    glake89's Avatar
    glake89 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 srx awd v6, 07 Solstice GXP
    Aug 2010
    Interlochen,MI
    81
    2,783
    There's nothing in the SM I could find indicating a TPMS failure would disable any other functions.
    Been fixin' cars for 74 years
  13. #12
    conedoctor is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 CTS AWD Wagon 2010 BMW X5 35D 2008 GL320
    Sep 2007
    2,621
    Ya I cant see that happening either as the spare does not have sensor.
  14. Remove Advertisements
